07-29-2020, 03:19 PM | #15 | |
Tampa Bay Camaros
Drives: 2017 Krypton Green 2SS Join Date: Jul 2011
Illuminated bow tie kit (84329529) Bracket (84684147) Steel bracket that goes behind grill (84684148) You will need to drill out a hole in 84684147 big enough for the bow tie connector to fit through it (about 1"). You will also need to cut a cross section of the grill (about 1" wide) right behind the bracket, for the connector to fit through. Then the steel bracket goes behind and holds it all in place. Steel bracket is made so that the connector does not interfere. Not sure why the other bracket is not made that way Then you snake the harness by the air intake box behind the front headlight. I reached in there via the fender liner. It connects plug and play to the headlight harness and connector Let me know if you have any other questions. Here is a pic for clarity.
Me and wife, in order
2011 2SS SGM 2013 2SS Hot wheels vert 2016 C7 DSOM 2012 2SS yellow vert 2017 2LT Krypton Green 2018 2LT Hot wheels crush 2020 2SS Shock vert. 2017 2SS Krypton Green coupe |
09-26-2020, 09:57 PM | #16 |
How difficult is it to swap out my illuminated bowtie ? I have water damage in mine it doesn't look good up close in daylight. If I purchase just the bowtie without the harness is this an easy job. Basically how do you pop the bowtie out to plug the new one in?
50th Anniversary, 2SS, Build#5771, A8, MRC, NPP, NAV, Sunroof, GM Performance CAI, Trifecta Tuned, GM splash guards, Black illuminated bowtie, GM smoked tail lights & third brake light, GM Fifty floor mats, Strut tower brace, JWM side markers, 20% window tint, Sto N Sho front license plate bracket
09-28-2020, 05:48 PM | #17 | |
Tampa Bay Camaros
Sent from my SM-T970 using Tapatalk
09-28-2020, 07:21 PM | #18 |
Drives: 2017 SS 1LE Join Date: Mar 2017
Agree on being dim. Wives Colorado is twice as bright as the camaro
09-29-2020, 03:39 PM | #19 |
Tampa Bay Camaros
So even the 2020 is dim, but a lot brighter than the 2018 for sure.
09-29-2020, 04:00 PM | #20 |
I just ordered a replacement illuminated bowtie without the harness since I can just re use my current harness. Not looking forward to removing this all the videos I've watched people seem to struggle at it.
09-29-2020, 05:02 PM | #21 |
Drives: 19 camaro19mustang72 chevelle 67pon Join Date: Aug 2020
Sadly for the price ...its just not bright enough
09-29-2020, 05:26 PM | #22 |
I actually like that it's dimmer than the DRL, after all, it's supposed to be an ambient accent and not some active lighting element.
