Old 05-25-2018, 08:48 PM   #1
Rich J
Drives: 2018 ZL1 Manual
Removing OEM center stripe from roof and trunk
I’m considering a new Camaro that already has the metallic black center stripe option. Has anyone removed one of those? Should I have any concern that the factory stripe might be harder to remove without paint damage? The car is white.
Thanks,
Rich
Rich J is offline   Reply With Quote
Old 05-25-2018, 08:52 PM   #2
KirkH
Blow dryer if you are worried, heat gun if in a hurry, to warm up the vinyl. Peel it off buy pulling it away or toward you flat, not straight up.
Probably will need to polish afterwards to remove all the adhesive and lines.
