05-19-2018, 08:53 AM | #15 |
Drives: 2019 Jeep Rubicon Sold:2017 ZL1 A10 Join Date: Feb 2017
Did you try pulling the negative?
Travis
SOLD ZL1 Summit White, A10, Black Strip, PDR, ZL1 floor mats Ordered 2/11, 2000 2/14, 3000 2/20, 3100 2/24, 3300 3/7, 3400 3/8, 4300 3/16, 4B00 3/21 Bayed at train yard in Ohio, 4200 3/26 All Abroad for the West Coast, 4800 4/4 Deliverd to portland train yard, 5000 4/7 3:00AM Deliverd to Dealer, 6000 4/7 6:45PM Delivered to Customer |
05-19-2018, 10:14 AM | #16 |
Drives: Red Hot SS 1LE Join Date: Dec 2015
Ok, pulled the cables and let it sit. Used different battery, same result.
Thinking that I might look at that bulletin and see if that does the trick. Man, it would be so easy just to flat bed it in. Too bad my trust level of a dealership is so low. |
05-19-2018, 10:25 AM | #17 |
Sellin Chevy's since '06
Maybe the battery in the Key is weak? Happened to me in my daily '17 malibu. Try different key or inserting the Key into the magic slot and see if it gets a better read.
'19 Z06-7Speed and lowered on stock bolts
'02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub40K orig miles. https://youtu.be/h6faSdcvNew TRADED!'17 ATS-V Coupe w/ Carbon Black pkg https://youtu.be/GH_t-R-TJV0 SOLD! '18 ZL1 Mosiac Blk SOLD!'16 SS Sedan-Forgestars/ARH/rotofab TRADED!2014 SS Sedan SOLD! 2013 Blue Ray1SS/1LE 1of20. TRADED! 2012 White 1SS/RS |
05-19-2018, 11:01 AM | #18 |
remote start does the same thing?
05-23-2018, 11:56 AM | #19 |
Well, I finally towed it in and today got the answer. The starter failed. They said they couldn't believe it.
That thought crossed my mind, I admit, but never thought it could be a real possibility. Case solved! |
05-23-2018, 12:36 PM | #20 |
Drives: Currently Looking for 2019 SS Join Date: Dec 2017
Camaro has that issue with the starter going bad. I had the same thing happen to me. Except it took them 2 weeks to figure it out. Those dealerships are something else.
05-23-2018, 01:31 PM | #21 |
Drives: 2018 Camaro ZL1 M6 Join Date: Jul 2017
I actually just had the same thing happen to my other car which is a jeep grand cherokee, but it turned out to be a loose grounding wire connecting to the alternator. Just tightened it up and it fired right up. That may also be a good place to check when something like this happens.
3000-9/18/2017 Received-12/1/2017 |
05-25-2018, 06:18 PM | #22 |
And the finale....
Picked it up today and everything is perfect. Washed it and inspected it. No scratches, no grease, no added miles. Very happy! Thanks out to Phil Smith Chevy! Sadly half the worry was created by the Internet forums. Just a sign of our times, I guess. |
05-25-2018, 08:58 PM | #23 | |
American Gearhead!!
Drives: ZL1 1LE/GT350/Ford RS/Gen 2 Raptor Join Date: Mar 2013
Thread Tools | |
