Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 12-08-2019, 08:11 AM   #1
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
BMR motor mounts
Just got these and was wondering if anyone else was running the solid aluminum upgrade and if so, whats it like? I still need to grab a transmission mount from Prothane too.
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 12-08-2019, 09:42 AM   #2
_Onyx_Wolf_
Onyx_Z7 <— Instagram
_Onyx_Wolf_'s Avatar
Drives: 2013 2ss 1le
Just ordered some as well, installed the rev shift poly mount and vibration was crazy for the first 300 miles or so but it seems to settle in about 1200 or so.
_Onyx_Wolf_ is offline   Reply With Quote
Old 12-08-2019, 10:04 AM   #3
Chris49066SS
Drives: 2010 SS L99
Nice. Hows it feel, more responsive? They were the only true solid mount I've been able to find and I am very excited to get them installed. I saw theres an MTI tranny mount for the manuals as well, but for the 6L80 guys it seems Prothane is the only option, at least from what I could find.
Old 12-08-2019, 10:17 AM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I don’t see a trans mount for a 5th Gen from Prothane.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is online now   Reply With Quote
Old 12-08-2019, 10:42 AM   #5
1fast
8.60 @ 157 @ 4200lbs
1fast's Avatar
Drives: 2010 Gen 5
Mounts
I run them very nice upgrade
2010 camaro twin turbo 8.60 @ 157 full weight 4200
1fast is offline   Reply With Quote
Old 12-08-2019, 11:09 AM   #6
Chris49066SS
Drives: 2010 SS L99
Heres the link on Jegs I have been looking at:
https://www.jegs.com/i/Prothane/311/...iABEgLWEPD_BwE
Excellent! Glad to hear this from someone with a dialed-in suspension. Thanks 1fast
Old 12-08-2019, 06:13 PM   #7
_Onyx_Wolf_
Hard turns are a little bit more planted and shifts are dead on as well, it’s a good upgrade if u don’t mind mild vibes every now and then in certain rpm bands.
Old 12-09-2019, 05:23 AM   #8
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Wow that’s a nice piece but looks like it might cause a lot of vibration.
Orange Krush II
Old 12-09-2019, 07:44 AM   #9
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
Using the Prothane engine mounts and rev shift poly insert...amazing difference in the "feel" of the car..much tighter all around...and have been on the car for 3+ years...
This is the first winter where the NVH is really pronounced until the car has been driven a few miles to warm up. Not that bad but I can't imagine what solid mounts would be like.
BTW - the Prothane mounts are extremely robust units and even with the poly mounts the engine twist makes the front right twist up slightly
good luck!
PEACE
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
frankwjr is offline   Reply With Quote
Old 12-09-2019, 08:50 AM   #10
go_go_gadget88
go_go_gadget88's Avatar
Drives: 2010 Camaro 2SS/RS ABM 6M
So, what exactly is the purpose of upgrading these? Or maybe the better question is, is what point does one need to look at upgrading the motor and trans mounts?
How bad is the installation for motor mounts with the motor in place?
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
go_go_gadget88 is offline   Reply With Quote
Old 12-09-2019, 09:46 AM   #11
_Onyx_Wolf_
Less movement and slop in the drivetrain which in turn saves wasted power that would have been absorbed through all the twisting and flexing.
Old 12-09-2019, 02:33 PM   #12
Chris49066SS
Drives: 2010 SS L99
Excellent. I don't do turns really, just the straight line, but any less deflection will be good. I've seen the motor jump on dyno pulls and I would rather it not do that.
Thats what I have read, that the solids increase NVH, and if you're on the fence or if thats a concern for you, its not recommended. I am one of those guys that doesn't care about NVH at all, thankfully.
good luck!
PEACE
Thanks Frank!
Just like we do solid cradle bushings and suspension upgrades, to eliminate deflection in the driveline. On when to upgrade them, either when you have a worn out OEM motor mount, or really just anytime you want to tighten things up. All the OEM stuff is geared toward NVH reduction and comfort. I don't care about either one of those things, as long as my car is more efficient at putting power to the ground.
I have read about people lifting the motor at the oil pan with a jack and a block of wood, but also bending the pickup tube in the process, or rupturing the pan. This is not what everyone would recommend doing, for obvious reasons, so I may be taking it to GPI for another round of mods, whenever that comes up.
