Vararam
Old 09-14-2018, 12:54 PM   #1
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
SS4 cam and other goodies
I've used this site a lot in the past year as a source of 5th gen knowledge and reference, and am grateful for the wealth of knowledge that is here on this site.
Until now my SS has just been simple bolt ons; just a K&N Cold Air kit and TSP long tubes, but I am taking it in to GPI on the 21st for these:
SS4 GPI VVT cam
Circle D 4k converter
3.91 1LE gears
ADM transmission cooler
Powerbond damper
18" Z06 reproduction wheels
Nitto NTO5R drag radials (will try the Mickeys next time)
I intend to get some BMR trailing arms and bushings, probably around the time I step up for some Mickeys.
Currently running 8.4 at 87 mph in the 1/8 with a 2.0 60', hoping to see those times improve!
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 09-15-2018, 10:13 AM   #2
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
You may want to of course do supporting mods for those done with trunnion upgrade to bushing, c5r chain; chain damper switch to dogbone, but many do without those and are OK. Just some thoughts to go with the install, toes at the same time also would be good since your doing 1/2 of the rears main supports to help wheel hop elimination. And well I would prefer the z28 even stock intake compared to a cheaper heat soaking induction tube that chromed steel is with most K&N that sell for cheap and of course there are threads on all these and comparisons and reasons. Hopefully you have stepped up to a good catch can long ago also..... Just some thoughts, like a ported TB.....etc …..new good plugs required etc...
christianchevell is offline   Reply With Quote
Old 09-16-2018, 01:41 PM   #3
Chris49066SS
Drives: 2010 SS L99
Oh definitely. I got the K&N back in 2015 when i first bought the car and all I knew back then was K&N. I have plans to upgrade to a good Rotofab unit and a Moroso catch can. Also the trunnion upgrade has been on my mind. The BMR trailing arms and subframe bushings will realistically be next. I will post some dyno sheets and time slips within the next several weeks
Old 09-16-2018, 05:40 PM   #4
KB85
Drives: Camaro
I had similar setup but with head work. Made 480rwhp. Car is fun to drive though
I have all the suspension work you talked about and it helps at the track. Only got one run in and couldn’t get it dialed in as track had oil spoiled. Ran 11.7
KB85 is offline   Reply With Quote
Old 09-16-2018, 06:29 PM   #5
Chris49066SS
Drives: 2010 SS L99
Cool, do you still have the car? Time for another trip to the track and get it dialed in!
Old 09-17-2018, 07:21 AM   #6
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
You won't be disappointed with the guys at GPI - the service is outstanding. The SS4 along with a 4k stall and 3.91s is going to completely transform the car - it'll be an animal.
Whether or not the NT05Rs will work for you will depend on how hard you want to hit it off the line. My experience is that they are really pretty decent, but they don't measure up to the Mickey Thompson ET S/S stuff in pure traction. At our power levels, that really only is noticeable right at the hit, once rolling they stay hooked up pretty good. Air them down, heat them up, and they are probably about 80% of what you need at the track. For the extended life (it's my understand they last 2-3x as long as ET S/S's) that's a sacrifice I may continue to make as someone that drives a lot.
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 09-17-2018, 09:06 AM   #7
Chris49066SS
Drives: 2010 SS L99
Definitely, and my reasoning was 3 fold for the Nittos; for one I've put a bunch of dough already so the Nittos were a little easier on the wallet. Two, I wanted to at least give them a try before I go to the Mickeys, so I have a good way to guage the improvements and be able to recommend them to others. And three, I was thinking about making the NTO5Rs my summer tire, keep a decent set of winter tires (all 4 corners) should I need them for those drives up to Michigan, and keep the Mickeys as a pure track tire, given they have a shorter lifespan.
Old 09-17-2018, 09:27 AM   #8
Chris49066SS
Drives: 2010 SS L99
http://https://www.youtu.be/LcgK_WnPRUk
Hope that link worked. The video is me racing a work buddy, pretty much the best i can do right now with the current setup
Old 09-17-2018, 09:49 AM   #9
acammer
acammer's Avatar
Link doesn't work. Good plan on the tires. I too will probably go to ET S/S's next time, but I bought my 18x11's with the NT05R's new on them, and figured I'd see what the difference is like. I don't hate the NT05R's - I start to think they don't have any grip, then I go back on my regular all seasons and remember just how good they are.
Old 09-17-2018, 09:59 AM   #10
bhillakaiceberg
bhillakaiceberg's Avatar
Drives: 2011 2SS/RS & 2017 1SS
Will be an awesome combo OP!
I have basically the same mods with Ported heads! Runs 10s all day!!
2011 Chevrolet Camaro 2SS/RS L99 (1 of 782)
10.78 @125mph ALL MOTOR SBE
Built/Tuned by Me
2017 Chevrolet Camaro 1SS Auto
9.29 @144.57mph ALL MOTOR SBE
#TEAMGPI Gwatney Performance Innovation
bhillakaiceberg is offline   Reply With Quote
Old 09-17-2018, 11:29 AM   #11
Chris49066SS
Drives: 2010 SS L99
Damn. One more try.
https://youtu.be/LcgK_WnPRUk
Yeah i would love to see 10s. Did you go with an aftermarket head or OEM ported? Again, I hear good things from Bo White's head porting.
Old 09-17-2018, 11:31 AM   #12
acammer
acammer's Avatar
Damn. One more try.
Worked that time. It's gonna be fun!
Old 09-17-2018, 02:17 PM   #13
KB85
Drives: Camaro
I'll be back out at the track next month. Car had more in it but I spun bad leaving. I had the NT05Rs and didn't care to much for them at the track. I tried M&H this time and when they are done I'll try out the Mickeys. By then I should know which one works best for my setup.
Old 09-18-2018, 09:51 AM   #14
bhillakaiceberg
Damn. One more try.
I have stock ported Heads - 280cc Advanced induction Heads. Bo White does GREAT work btw. I have his Stage 3 TB on my car as well.
Circle D 4C and 3.91 Gears. SS4.5 Camshaft.
Built/Tuned by Me
