10-27-2019, 05:57 PM | #1 |
Drives: Camaro ZL1 Join Date: Jan 2018
Change from normal ZL1 to ZL1 1LE or upgrade parts
Hi all
Yesterday, I took my normal ZL1 to the track. The car worked great and the power is just amazing. Goimg forward, I would like to use racing slicks to add grip. However, I felt that the back was relatively soft accelerating out of corners. Now I kinda wish I had gone with the 1LE..... Is there a way to upgrade to the 1LE suspension? What are all the parts that need to be changed and how much would that cost including fitting? Does that even make sense? Also, racing slicks are a lot more available in 18 inch, so I guess I need some new wheels. Anyone has a good recommendation for 18 inch wheels that dont cost an arm and a leg? cheers cirpower |
10-27-2019, 07:45 PM | #2 | |
Drives: 2012 Porsche 911 Turbo S Join Date: Jan 2017
https://wildhammermotorsports.com/ca...t-performance/ https://wildhammermotorsports.com/ca...t-performance/
IG: 2fast2nick
-- Current -- 2012 Porsche Turbo S - PDK - Basalt Black Metallic -- Past -- 2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101 2015 Mustang GT PP - Whipple Supercharger |
10-27-2019, 08:16 PM | #3 | |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
All you need to do to tighten up the rear-end is add either a rear cradle lock-out kit or swap out the rear cradle bushings for solid ones. That makes all the difference.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
10-27-2019, 09:00 PM | #4 | |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
I'm not sure how much track time you have in total, but I'd focus on getting the most out of the factory parts first. There is more in driver-mod than parts typically. If you have tons of experience, then disregard.
10-27-2019, 09:25 PM | #5 | |
Drives: gas powered Join Date: Jan 2019
yeah all the aero stuffs just a gimmick.... and the brakes.... and the tires.... and the added camber top hats.... And the DSSV shocks thats stupid stuff F1 uses just to get a multimatic sticker on there car.
10-27-2019, 09:46 PM | #6 |
aka BeastZL1
I think the point is that the novice driver or average driver is going to see a bigger difference from the Goodyear 3R's vs the GYSC3's instead of anything else.
There is no difference in the brakes between the ZL1 and the ZL1 1LE except the caliper color.
10-27-2019, 09:47 PM | #7 |
the red color adds slightly more performance
IG: 2fast2nick
10-28-2019, 05:04 AM | #8 | |
Thank you Al Oppenheiser!
https://www.camaro6.com/forums/showthread.php?t=562504 |
10-28-2019, 03:35 PM | #9 | |
Yes, all those other things help obviously, (with the biggest factor being the 3R tires), but I was specifically addressing the non-tight feeling of the rear-end. Yes, the DSSV shocks are bad ass and used by F1 race cars, BUT the MRC is also great and from those who have swapped, they found no time savings by swapping. They are simply more track focused and 1 dimensional. The weakest link going from the ZL1 1LE to the SS 1LE / ZL1 are the rear cradle bushings and tire grip. Those 2 items will get you 95% of the handling side of things. The brakes are just as great on all 3 trims, you can get about 2.2 to 2.5 camber on the ZL1 and SS 1LE. Aero is really a non-factor until triple digit speeds, and while the ZL1 has less aero than the ZLE, there is still enough there to keep things planted. In fact, I would wager that additional down force and/or grippier tires on those rubber cradle bushings will cause more instability, as you are putting more stress on them (higher G loads on rubber bushings is BAAAD) You have to keep in mind that the suspension system is ALL components working together as a cohesive package to create a sum. When upgrading, start from the foundation and work your way up the chain. OR, just upgrade to the ZLE if all you want to do is have a dedicated track car.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 Last edited by TRZ06; 10-28-2019 at 03:54 PM. |
10-29-2019, 10:19 AM | #10 | |
Drives: 2013 C6Z06 Join Date: Nov 2016
I don't agree 100% with what I bolded as the factory rubber bushings can still handle more stress, but we all know they are a weak link and less rubber in the suspension bushings is better. OP: On some tracks the aero will be more of a hindrance than a benefit also |
10-29-2019, 10:41 AM | #11 |
Drives: 22 ZL1, 20 Taco, 20 Cayenne S Join Date: Oct 2019
After modding a few cars suspensions/tire sizes etc they were better (especially my GT350), but it still didn't feel completely right. Almost like certain things weren't playing nice together as a cohesive package. Which, is why I went with the ZLE. I don't find the ride that bad, of course on really bad roads it is, but so were so some of my previous cars. Especially my first 15 M3 static suspension, which was worse in terms of ride and much worse when it came to doing what it was supposed to do performance wise. At least with the harsher ride you get a world class suspension setup with the ZLE.
10-29-2019, 11:19 AM | #12 | |
I hated my 16' M3 suspension so much I moved to the Ohlin R/T coil-overs, and even then, like you said, it didn't work all that great as a cohesive package. The ZLE is a great choice that is built right, right out of the gate. I think I am just at an age now though, that I wouldn't want the ride penalty as a daily. That is why the ZL1 or SS 1LE with MRC and a few select mods is the best of both worlds.
Current:
10-29-2019, 11:22 AM | #13 | |
Current:
10-29-2019, 11:24 AM | #14 |
Who Needs to KNOW?
Save money for seat time and tires.. and track insurance. and brakes, novices are hard on brakes.
ing for grip.
