Old 10-11-2018, 10:19 AM   #1
Baddawg53
Drives: 17 hyper blue 2SS M6
Flex fuel tune ... Cranking
After my flex fuel install, the car starts just a little bit harder when it's cold. The timing table alcohol adder is all zero's. Rather than randomly trying numbers, I figured I'd ask. Is the cranking adder more than just a couple of degrees typically?
Baddawg53 is online now   Reply With Quote
Old 10-11-2018, 10:49 AM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
yes... from -40 to 90 degrees you need to add timing from 30-100% E content. 7 degrees -40/30%, 12 degrees -40/100%. 1 degree 90/30%, 6 degrees 90/100%. Populate everything in between linearly.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 10-11-2018, 11:09 AM   #3
Baddawg53
Thanks for the help, I couldn't find that information anywhere.
Old 10-11-2018, 11:32 AM   #4
lokitwitch04
Drives: 2017 Camaro SS 2SS
0 7 8 9 10 11 12 12 12
0 6 7 8 9 10 11 11 11
0 5 6 7 8 9 10 10 10
0 4 5 6 7 8 9 9 9
0 3 4 5 6 7 8 8 8
0 2 3 4 5 6 7 7 7
0 1 2 3 4 5 6 6 6
0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0
This is what my alcohol adder table is at for cranking.
edit: it made the numbers weird, but that's the whole table.
lokitwitch04 is offline   Reply With Quote
Old 10-11-2018, 11:52 AM   #5
Baddawg53
0 4 5 6 7 8 9 9 9
0 3 4 5 6 7 8 8 8
0 2 3 4 5 6 7 7 7
0 1 2 3 4 5 6 6 6
So I'm assuming the last 3 in each column repeat because you're never going to be over 85%. I wouldn't have done it that way but it makes sense now.
Old 10-20-2018, 12:31 PM   #6
TJay74
I put these in my truck this morning, should be able to see later if it helps out or not.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
