Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 06-23-2022, 07:48 PM   #1
Murphdriver
Drives: 2010 rs/ss
17 inch VMS drag wheels TIGHT fit
I put my 17x10 vms drag wheels on and it is so close to the calipers.
Less that a zip tie..lol
I will be drag racing so spacers are out of the question but has anyone had any issue with caliper rub?
I've read all over they fit, never seen anyone mention how close..lol
Tyty
Murphdriver is offline   Reply With Quote
Old 06-25-2022, 03:07 PM   #2
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
I run a 5mm hub centric spacer on mine. I did swap out the wheel studs to ARP's while I was at it. After that I swapped to a 15" conversion brake kit and still run the hub centric spacers.
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 07-18-2022, 10:07 PM   #3
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
I run a 3mm hub centric spacer on mine.
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 04-15-2024, 12:46 AM   #4
brandon_20
Drives: Camaro 2011 RS v6
Were you able to use the VMS with the tight fit?
brandon_20 is offline   Reply With Quote
Old 04-15-2024, 05:23 AM   #5
Ashen 6.2
Ashen 6.2's Avatar
I didnt try with mine, it was way too close for my comfort.
