Old 08-26-2020, 01:08 PM   #15
CC2018SS1LE
Drives: 2018 Chevy Camaro ss 1LE
Originally Posted by TheRealJA105 View Post
Yep, came here to say this. Go with a BMR rear bar.
You use with the stock front bar?
CC2018SS1LE is offline   Reply With Quote
Old 08-26-2020, 01:12 PM   #16
CC2018SS1LE
Do you use with the stock front bar, or do you also use the Hotchkiss front bar?
Old 08-26-2020, 01:15 PM   #17
CC2018SS1LE
Do you use the BMR bar with the stick front bar, or are you using the front Hothhkis bar, that was recommended in one of the previous posts?
Old 08-27-2020, 10:11 AM   #18
CC2018SS1LE
Thank you
I just ordered one
I’m also going to do the track alignment
Old 08-27-2020, 10:30 AM   #19
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
I have BMR front and rear adjustable bars. Have a big thread on front bushing issues https://www.camaro6.com/forums/showthread.php?t=576751
I like the bars and the way my car handles with middle front setting and full stiff rear setting. I suggested only the rear bar for you to get more oversteer that you are asking for.
Old 08-27-2020, 02:10 PM   #20
CC2018SS1LE
Agreed, I just got the rear bar, I like the way the front bites with stock bar
Thanks for suggestion
Old 08-27-2020, 03:06 PM   #21
eimarshall
eimarshall's Avatar
Drives: 2018 SS 1LE Hyperblue
The track alignment will do wonders for turn in. I ran 20K miles on the street and the alignment was around -2.0 front the whole time. I had a set of all seasons for DD duty but they were in fantastic shape afterwards.
eimarshall is offline   Reply With Quote
Old 08-27-2020, 05:19 PM   #22
CC2018SS1LE
Good to know, thank you
I just have to find a good alignment shop, locally
Old 01-05-2021, 09:19 AM   #23
CC2018SS1LE
Originally Posted by Matos1LE View Post
The wonky alignment that comes on them from the factory will kill your tires much, much faster than track alignment. My tires are wearing much more evenly with the track alignment despite tons of daily driving on the streets. Would recommend getting the alignment done before you change the sway bar.
I took yours and other peoples advice and did the track alignment, made a big difference. It almost dialed out all of the understeer
Thanks for the advice
Old 01-05-2021, 09:34 AM   #24
Nothing like an SS
Faster!!!
Nothing like an SS's Avatar
Drives: 2020 Camaro 1SS 1LE
Where did you take it for alignment??? Interested Long Islander......lol
Thanks!
Nothing like an SS is offline   Reply With Quote
Old 01-05-2021, 12:12 PM   #25
NYblack1le
Drives: 2018 1SS 1LE
Thanks!
RCT performance in westbury! Make and an appointment and they’ll have you in and out in less than an hour.
NYblack1le is offline   Reply With Quote
Old 01-05-2021, 12:34 PM   #26
Nothing like an SS
Faster!!!
Awesome! First stop after spring rebirth!!! Thank you!
Sorry for the hijack all, please resume.
Old 01-07-2021, 07:51 PM   #27
CC2018SS1LE
Thanks!
I actually got it done in Florida, Fort Lauderdale, they did a great job
Was only $100
I take my car to Florida, for the winter, I do track days, there, then bring car back up north, for spring and fall events
I took car to PBIR, it was a big improvement , over stock.
In fact I purchased a BMR rear adjustable sway bar, befor I did alignment,I do not think I even need to install it, car is so good
Old 01-07-2021, 11:44 PM   #28
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
The other thing I've noticed: I've since gone with 10mm wider tires than stock up front, seemed to make a noticeable difference in over/understeer, people watching from the sidelines told me "I've never seen a Camaro over-steer before!". They are likely not knowledgeable on the 1LE, but it was fun to hear.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
