Old 03-27-2019, 01:13 PM   #29
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
Great info DorkMissile, what i meant by being dependant is on a general scale... using meth for cooling down is technically the same thing... its only cooling down thanks to the meth, so with meth isnt in there... then the temp raise can be really really bad....
I mean at the end of the day my goal would be 600hp and able to run full E while being ok for very occasional roll racing at mexico.
Great great numbers man im sure thats a blast.
OG: Pray Perf FBO ET:11.5 @119 THEN:LT4 SC, E85 + Meth :10.6 @135 NOW: H/C Whipple 416ci
G2K is offline   Reply With Quote
Old 03-27-2019, 07:08 PM   #30
DorkMissile
DorkMissile's Avatar
Drives: 18 1SS 1LE HyperBlue
Originally Posted by FrostySS View Post
I had ECS install my kit themselves, with their tune I hit 555hp and 528tq at the wheels on an otherwise stock car aside from deleting the secondary cats(not really a mod for horsepower). 93 octane, stock fuel system, the regular 8# pulley.
As reference - my setup on the LT4 fueling with 9.5-10lbs and Minnesota premium (91 e10) was 595H/572T with the Meth turned off (just reference for 10lbs vs 8). The Meth took the same setup to 673H/574T.
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
DorkMissile is offline   Reply With Quote
Old 12-22-2020, 09:14 AM   #31
Phil 2018SS
Drives: 2018 Camaro SS
Makes my 555hp at the wheels look puny, thanks a lot....
How do you like the base kit? Interested in one myself. What RPM does it kick in? Does it go into boost at full throttle only or mid to heavy throttle?
Phil 2018SS is offline   Reply With Quote
Old 12-22-2020, 09:43 AM   #32
FrostySS
FrostySS's Avatar
Drives: 2018 Redline Edition 2SS
Honestly I'd have to check I would say probably three quarter throttle.
Also on the side note I had a local shop to me retune it and it put down 589 to the rear wheels in 80° weather the only other change was getting rid of the catalytic converters. I'm sure in this cold weather I'm probably close to 600 at the wheels.
The next time I drive the vehicle I'll do some testing for you and shoot you a PM.
2018 Redline Edition 2SS- A8, NPP, MRC, Recaro seats, ECS Novi 1500 tuned by EFX, cat deletes, Mighty Mouse Wild CC, GM STB, smoked ZL1 3rd brake light, Xpel XR Black 35% tint all around, Street Scene front splitter, C7 Carbon ZL1 side skirts Drake Muscle Car wicker bill, Adams Polishes Ceramic Coating
2010 Infiniti G37x Sedan for the DD.
FrostySS is offline   Reply With Quote
Old 12-22-2020, 11:41 AM   #33
Phil 2018SS
I appreciate that. Thanks
