10-12-2020, 08:12 AM | #211 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
10-12-2020, 08:56 AM | #212 |
L83 5.3 to be exact.
2016 NFG 1SS A8
10-12-2020, 09:31 AM | #213 |
Drives: 2019 SS Join Date: Apr 2020
I live down the street from Thompson Motorsports, their engines are really really good, I would not use TSP any longer their quality has suffered in recent years.
10-12-2020, 04:41 PM | #214 |
Drives: 2016 Camaro SS Join Date: Sep 2018
10-12-2020, 05:21 PM | #215 |
I have heard good things about Thompson as well.
2016 NFG 1SS A8
10-13-2020, 06:58 AM | #216 |
Have you decided if your going to do a stroker?
10-13-2020, 07:43 AM | #217 |
Drives: Turbo 6.2 Join Date: Feb 2019
Not sure as of now. I talked to Thompson. They have a 416 forged crank, rods, pistons, arp hardware, oil pump, their stage 3 cam (240 246 0.630 0.630 116.5+6), timing set - rated to 1100 flywheel with a 12 month warranty for $8500. Its a bit of money but hard to beat that 12 month warranty with 950 rwhp. Add heads and Im sitting around $10K.
A factory LT4 with a cam kit for ~$8500 LT1 with drop ins and cam kit for ~$7000
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
10-13-2020, 08:14 AM | #218 | |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
Baby Blue
10-13-2020, 08:38 AM | #219 |
I didn’t ask but yes that oil pump, timing set and cam is part of their warranty.
10-13-2020, 08:52 AM | #220 |
Have you looked at LME? You can get a LME 377 LT4 shortblock rated up to 1400whp for 8373.00 or a LT1 rated for 1100whp for 7596.00. I believe the 416 is 9538.00 but I really don't see the point of mainly increasing stroke for a FI application. If I was wanting to add cubes then it would have to be a darton sleeved 427 for the larger bore.
2016 NFG 1SS A8
10-13-2020, 09:20 AM | #221 |
it would be interesting to have more info on that pump. I'm sure you're aware of all of the failures on OEM pumps. I know that Melling supplies the OE variable pressure pump. There are no other off the shelf pumps available to my knowledge. Given that Thompson refers to this pump as a High Pressure pump, I'm guessing they may be modifying stockers to defeat the variable volume/pressure functionality, and in doing so possibly mitigating the outer gear cracking issues that have plagued a not-insignificant number of cars.
Baby Blue
10-15-2020, 04:25 PM | #222 |
Drives: Chevrolet Camaro 2SS Join Date: Jul 2019
I am part of the club also of broken stock exhaust valve on stg2 ported head. I should have upgraded but didnt think 600hp n/a was gonna kill a 1K hp rated engine..
Just ordered a new block, Mahle power pack pistons, callies crank, and will looking into rods |
10-15-2020, 05:42 PM | #223 |
These destroyed engine from dropped valves is scaring me since I didn't touch my heads except springs, pushrods and a trunion kit.
Sent from my SM-N986U using Tapatalk |
10-15-2020, 06:44 PM | #224 | |
