Old 09-08-2021, 08:16 AM   #1
raidaru
Drives: 2SS
Need original ECU software for 2016 SS
Hi, my SS is running like $hit , very rich but no fault codes, I thought I might check if the sw on it it's tweaked before I start disassembling the engine. I've made a backup of my sw with FLEX. I either need an original sw file or maybe some of u guys can compare them for me. I attach the sw from my SS. Thanks!
File Type: zip gm_delco_e92_obd_full_fullbackup_full_backup_20210830115924_int_flash.zip (1.43 MB, 90 views)
raidaru is offline   Reply With Quote
Old 09-09-2021, 07:51 AM   #2
I would check in with Ted Jannetty. He's great to deal with, does a lot of remote tuning and could check it out for you.
https://jannettyracing.com/
Old 09-09-2021, 09:09 AM   #3
Nitefall17
Drives: Camaro 1SS A8 Vert
Do you have a throttle controller??? If you do it will run super rich when you flash ECU with HP tuners or factory.
Nitefall17 is offline   Reply With Quote
Old 09-10-2021, 01:41 PM   #4
raidaru
Drives: 2SS
From what I see everything is stock, but idk, mby a cam is installed, or mby there is a bad aftermarket tune, hell knows, that's why I want to check the tune to see if it's factory or tweaked.
