10-01-2018, 02:57 PM | #1541 |
Drives: 2018 1SS Join Date: May 2015
After 8 weeks of rain outs I got to make two passes last Sat .. The place was too packed to get more than 2 passes ..
Tires used on the pass: Stock Goodyear run flats Performance Mods (if any): None Category submitted for: Please List the Category or Category # Bone stock 1SS A8 R/T...........124 60'............. 1.81 330'........... 5.146 660'........... 7.87 660’ mph... 89.30 1000'.......... 10.198 1320'.......... 12.17 1320’ mph… 112.81 Name of the track: BMP FL Date of pass: Sep/29/2018 Weather conditions: Include Density Altitude if known. @ 6:00 PM DA was Density Altitude: 2291 feet Relative Density: 93.47 % Please add me to the Bone Stock A8 list ... Thanks .. Last edited by smokinzx14r; 10-01-2018 at 03:03 PM. Reason: Added DA Numbers .. |
10-01-2018, 03:21 PM | #1542 | |
10-02-2018, 07:07 AM | #1543 |
Great pass Dub, glad you chose the Hoosiers for that stick car, you'll save part in the long run. If you could knock off a little on your 60 ft you could get really close to that 10 second pass.
10-02-2018, 07:14 AM | #1544 |
Drives: 2016 2SS Join Date: Jul 2016
10-02-2018, 07:23 AM | #1545 |
Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
Thanks! Hoping to get a few more runs in this year still and knock off alittle more time
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
10-02-2018, 04:59 PM | #1546 |
Drives: 2016 1SS M6 Join Date: Jan 2018
Nitrous camaro
Hey guys sorry it took me a while to post these. I felt it was pretty amazing for the money. Only mods are,
Radials Drop in filter Pre cat delete Nitrous/no tune. |
10-02-2018, 05:07 PM | #1547 |
Assuming your the car in the 11's.
10-02-2018, 05:08 PM | #1548 |
Dub, what RPM are you launching at?
10-02-2018, 05:13 PM | #1549 |
10-02-2018, 05:19 PM | #1550 |
Jones, sounds like your getting the combination down. M6s are not easy to launch but your doing it pretty well.
10-02-2018, 05:23 PM | #1551 | |
I originally come from racing 2j and SR swapped 240s. Trying to get back into it. |
10-02-2018, 07:34 PM | #1552 |
4300 ish. I am having some tire slip on my rims. I was going to try screws but ultimately decided to get beadlocks this winter so i don't want to ruin these wheels. I gotta get brave and try NLS on the 1>2 again. I'd tried it a few times before and it didn't work out. Works fine on the other shifts.
"Spitfire" 427ci
10-03-2018, 08:10 AM | #1553 |
I have mine screwed down, way cheaper then buying bead locks. I run 5 screws on each side of the wheel. Mine hooks on gravel with the Hoosiers and I didn't screw them down until I boosted mine as they were spinning on the wheel a lot.
10-04-2018, 05:43 PM | #1554 |
Make sure they don’t use a non alcohol based lubricant while mounting the tires on the wheel. I use hairspray or belt dressing as the lubricant. Sounds dumb but it worked on all my cars. No slip.
