05-04-2022, 09:09 AM | #15 | |
Drives: 14 Camaro SS 1LE Join Date: Feb 2019
The issue that you are bringing up, we have not seen with our packages. There aren't many other companies that have the testing capability we have. It is possible that other companies see unideal side loading if there valve-tip to stem sweep pattern is off. We have verified in our setups, that the sweeping pattern on the valve tip is correct. If you run into a situation where the nose of the valve goes over the edge of the valve tip at peak lift, you will get into a situation of severe sideloading. In our LTK track attack package with our custom cylinder head, our valves, our geometry, we run over .700 lift on the intake and exhaust. This came back to us after 40 hours of track mileage with virtually no wear as well. This was also hydraulic roller. |
05-04-2022, 09:58 AM | #16 | |
2016 NFG 1SS A8
05-04-2022, 11:43 AM | #17 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
Great info guys.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
05-04-2022, 02:05 PM | #18 |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
Great info here, not many vendors respond quickly and with honest, fact based answers. Props to you guys Zach!
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
05-04-2022, 02:16 PM | #19 |
Drives: E92 BMW M3 Join Date: Oct 2012
Makes me want to do business with them first chance I get!
J-Rod Built and Matt@FSP Tuned |
05-05-2022, 07:48 PM | #20 |
Drives: 2018 Camaro SS 1LE Join Date: Jun 2020
I'm hoping for 600hp out of the Katech build on my 2002 Camaro SS. Maybe next I'll send my 1LE in for a 427.
2002 Camaro SS | 2003 Corvette Z06 | 2008 Corvette| 2016 Corvette Z06 C7.R | 2018 Camaro SS 1LE
02-15-2023, 11:04 AM | #21 |
BLUPRINT_1LE
Drives: 2022 Rapid Blue SS 1LE Join Date: May 2017
Just now seeing this and was worried about the valvetrain as well since I won’t be close to Katech as I am now but this definitely made things a lot more comforting to me.
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- |
