01-18-2019, 03:46 PM | #57 |
Drives: 2016 2SS Join Date: Oct 2017
01-18-2019, 04:52 PM | #58 | |
Drives: 2018 SS 1LE Join Date: May 2018
Everything sent back and am just forming over the $99 for an OBDLink MX+ Module
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune https://instagram.com/corn_sauced?ut...d=o0ako89uurwl Last edited by JonD; 01-20-2019 at 07:04 PM. |
01-21-2019, 05:29 PM | #59 |
Well i’ve Tried my OBDLink MX+ with the OBDLink app on my iPhone and have entered the custom PID below...
OBD Mode: 22 PID #: 220052 Equation: (A/255)*100 Still Nothing, yet when somebody else with an OBDLink MX & the Torque App on their Android plugs in they instantly get my ethanol %. Does anyone have any experience with the iPhone Apps specifically?
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune https://instagram.com/corn_sauced?ut...d=o0ako89uurwl |
01-22-2019, 02:06 AM | #60 |
Drives: 2018 Camaro 1SS Join Date: Jun 2018
General question. When its require or better upgrade fuel line? There are few E85 kit in market, some comes with fuel line but some doesnt.
2018 1SS 6MT: SOLD
01-22-2019, 08:27 AM | #61 | |
Ted.
www.jannettyracing.com
01-22-2019, 08:28 AM | #62 | |
Ted.
01-22-2019, 01:01 PM | #63 |
Thank you
2018 1SS 6MT: SOLD
01-26-2019, 08:49 PM | #64 |
Drives: Camaro Join Date: Sep 2018
So when I add my E85 kit to my N/A LT1 with headers, no cats, CAI, 95 TB & ported stock IM will the stock fuel system be okay? Also after the tune for E85 can I still use 91 octane?
01-27-2019, 06:27 AM | #65 |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
Yep your fuel system will be just fine and yes you can switch from 91 to E85 or vice versa whenever you want.
01-27-2019, 07:17 PM | #66 | |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
It's the benefit of 'FlexFuel' vs a static E30/E85 tune. Run whatever gas is avail...the computer will adjust. It took less than a mile for my ECU to adjust from 93 octane to E85.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
01-27-2019, 10:39 PM | #67 | |
Changed the PID Number to 0052 In the Torque app the Mode and PID are entered together on a single line i.e. 220052, but in the OBDLink app the Mode and PID are entered on separate lines i.e. OBD Mode = 22, PID Number = 0052
02-11-2019, 12:58 PM | #68 | |
05-14-2022, 01:45 PM | #69 |
Drives: Camaro Join Date: Apr 2021
Question about ZL1 with LT4, fully stock. If the flex fuel sensor is installed and car is tuned for E85, how much HP will it make over stock setup on 93 gas?
If car is tuned for E85, can it run other mixtures safely? Like E30-E50 and anything in between? And last question, does E85 make engine run hotter or cooler compared to pump gas? How does it affect factory catalytic converter? Thank you. |
05-16-2022, 07:03 AM | #70 | |
Once the car it converted to Flex fuel you can run any E content from Zero up to E60. Do not try and run E-85 You should add a JMS fuel system voltage booster to be able to run anything over E-30 up to E60 Engines typically run slightly cooler on E fuels. There is no effect on cats.
