02-28-2017, 10:13 AM | #15 |
Drives: 2018 1SS Auto Mosaic Black Metalic Join Date: May 2016
I have the same problem the engine revs so fast going from first to second you have to shift sooner or it will hit the rev limiter. It seems that the manuals have the rev limiter cut the fuel to the engine.My wife's is a auto and hers just sputters when I hit the rev limiter.I found out when I shift from 1st to second I have to shift when tach is at 6500 or less and it doesn't cut out.You just have to practice different shift points till you find the right rpm. It took me awhile to figure it out and I still hit the limiter sometimes but I'm getting better.Ive never had a manual that is so touchy between 1st and second. All the other shifts there's no problem.
03-02-2017, 04:02 AM | #16 |
Drives: Camaro V6 Join Date: Oct 2016
Do the 5th gens do this? Or, is this just a problem with the 6th gen?
When I shift mine, I can get to 7K rpms before the rev limiter kicks in. |
03-03-2017, 08:03 PM | #17 |
Drives: Mitsubishi Evolution X Join Date: Nov 2016
How accurate (lag) is the rpm gauge?
08-03-2018, 12:34 AM | #18 |
Drives: 2018 Camaro SS 1LE Join Date: Jun 2018
Bumping this thread up so I don’t have to start a new one. This has been happening to me too. What the hell. I’m shifting well before 6500 rpms and the engine cuts out
Current:
2018 1SS 1LE - stock Past: 2008 C6 - heads/cam/boltons 2005 GTO - cam/boltons |
08-07-2018, 08:06 PM | #19 |
Bump
Current:
08-07-2018, 08:22 PM | #20 |
Thank you Al Oppenheiser!
Take your foot off the clutch pedal. If you so much as make the slightest touch on the pedal with your foot the car will cut power.
08-08-2018, 09:45 AM | #21 |
thanks for the response, my style when shifting is that i always have the clutch depressed a tad when shifting aggressively, so that i can get to the engagement point smoother. In fact i wanna say thats how i always drive, I never come all the way out of it
Current:
06-06-2019, 09:39 AM | #22 |
Drives: 17' V6 1LE Join Date: Aug 2018
Reviving this thread because I had a similar issue but recently I found out it could be the no lift shift feature that's causing the issues. If I don't lift off the gas and let the no lift shift feature do it's thing it's perfect, but if I forget and do lift the throttle when shifting close to redline sometimes I get that abrupt fuel cut
06-06-2019, 09:27 PM | #23 |
Drives: 2018 CHEVROLET Camaro LS LGX/TR3160 Join Date: Apr 2019
Yep, don't not even breath on the clutch pedal or the compy will shut you down. You can tach it out, just have to stomp on the clutch pedal. Do not rest your foot on it.
LorenZo
2018 CHEVROLET Camaro LS -The Giant Black SEALION- LGX/TR3160 w/BOZE!!!!! ig: rapidtransit |
06-07-2019, 11:58 AM | #24 |
Drives: 2017 1LS 1LE Join Date: Jul 2017
Interesting reading. I've been having the same 1-2 shift issue, but never noticed it until I had a supercharger installed. I'm guessing that the additional power amplified the effect. I have the Tremec M6 and figured it was the weak factory clutch slipping (so I dropped it at Spec clutch to develop a twin disc unit). Will have to pay more attention to the clutch pedal when I get it back.
