04-20-2017, 09:33 AM | #71 |
Drives: 2016 2SS Join Date: Jul 2016
The procharger guys have mentioned it in multiple threads. I will see if I can get them to chime in here.
04-20-2017, 09:57 AM | #72 | |
Drives: Many C7's Join Date: Apr 2014
Well, I don't have any links, I just have the LT1 motors I have been around since the end of 2013... If you ask shops such as Cunningham motorsports, Vengeance, CBI, RPM, etc. you will get the same answer about one of the "weak spots" of these engines. Calling it a "weak spot" is really unfair to GM, because its not "weak" nor is it built "wrong".... it's just that the ring gaps are not ideal for high HP or boost. These LT1 engines are designed to pass the crazy tight emissions testing that is now in place. Which is drastically different then it was 10 years ago. And with that in mind these LT engines have some of the tightest ring gaps I have personally ever seen. Not only are the gaps very very very tight. There is an inconsistency to them, and that inconsistency is why "some live" and "some don't" when it comes to big power and long highway pulls. (even if the cars are tuned the same, and have the same modifications) EXAMPLE: When a guy takes a "junk yard" LS motor and goes to make big power with it, one of the first things they do is open up the ring gaps... since all it takes is the time to take the motor apart,...file the rings to say .020-.028 gap (depending on power level, bore, and acceptable blow by) Once that is done, the chances of the rings "butting" is pretty much eliminated, and the pistons live a long and happy life. (until 25+ psi of boost is shoved in them. lololol. ) And even then many live a long long time. THE LAST LT1 that I took apart to inspect had a factory ring gap of .008 on one slug, .009 on the next, and .012 on the remaining (6) slugs. Those two "tight" holes wouldn't survive long duration highway pulls no matter how "safe" the tune is. Thermo expansion would put an end to that fun in a hurry. So there are a couple things to remember here..... 1) 1/8th mile, and 1/4 mile races are far far less stressful 2) Thankfully both a "drop in piston" and a "Drop in Piston/Rod" packages exist 3) If the piston does break, it usually doesn't hurt the block or anything. 4) With normal driving, spirited driving, 1/4 mile or less racing its pretty unheard of to break an LT1. So I guess if you are doing something like a camshaft swap, and want to have a bit of a "peice of mind" do one of the following..... 1) pull the pistons out and re-gap the rings 2) throw a set of "drop in" forged pistons in there. I only say that, since if you are doing a camshaft, you got like 90% of the motor apart anyways. LOL. If you aren't doing a cam swap, just be safe with her, and enjoy the fun. SIDE NOTE: I have had someone say "well a CTSV can do it, why can't I"....well, for a couple reasons. Engines like the CTSV (LSA), the LT4, Hellcat, 2003/2004 Cobra, Boss302, etc. Are all forged motors, and (3) of the four I listed above were designed for BOOST! So they have ring gaps to handle boost, they have pistons designed for boost (and heat) plus other items. Those engines are like beer mugs... to the LT1 being a wine glass. The will both hold water... but bang them together a few times and tell me which one lives. |
04-20-2017, 10:44 AM | #73 | |
Drives: Black Join Date: Jan 2017
If your talking about driving characteristics and that you'd be using more hp out of the supercharged motor on a daily basis, that's not really relevant as that depends on the user. The major downfall of aftermarket forced induction is really it's more like an unlimited bottle of nitrous or kers. You can't use it continously for a long period and it creates a more unpredicatable power band. (Well you can if you take great lengths to improve cooling like a manufacturer would) Thankfully you can use forced induction long enough to reach speeds deep into triple digits, so not much of an issue on the street. Back in the 90's I had 8 gauges in 2 gauge pods, including oil temp, water temp, egt, and ait, crazy what happens after 10-15 seconds of boost. |
04-20-2017, 11:09 AM | #74 |
Drives: 2023 2SS Convertible Join Date: May 2009
Great post from ProCharger. Thank you!
What do you guys think of the gapless rings with the sliding ring gap? (total Seal or similar brands). -Geoff
04-20-2017, 11:18 AM | #75 | |
04-20-2017, 12:26 PM | #76 | ||
Probably tired right now
Drives: 1Lap1LE | EV6 FE | 18 F150 Join Date: Sep 2010
It's another reason I'm considering heads cam over blower. However if I do H/C - I'd be lying if I said I didn't consider nitrous too... which is going to be hard on the engine/affected by ring gap as well. Quote:
If I'm going off-warranty... and paying the same money regardless, I'm gonna get the most power I can for my money (within reason - and within drivability constraints/preferences)
-Seven
'17 SS 1LE - 1LAP 1LE (Now with more 427!) '18 F150 Platinum Powerstroke diesel '22 Kia EV6 First Edition '18 RS3 (1 of 2) Cumulus Blue '24 911 T (ordered) Formers... '19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor |
04-20-2017, 01:37 PM | #77 |
Drives: SS 6 speed of course Join Date: Jan 2016
On my rice rockets, I run gapless. I have no experience with gapless on a piston as big as a LT1 102mm, my pistons range from 81 mm to 86mm. there is a vedor here with a forged lower CR piston drop in (same weight as stock piston).... but in the end this is a $3000 port and small cam thread, DIY and that is going to be IMPOSSIBLE for a supercharger to replicate.
04-20-2017, 02:32 PM | #78 | ||
b) as I've already stated, the amount of time a DD spends from 6200 to 6600 fuel cut is minimal, meaning very little impact on long term reliability. c) the only "safer" would come into questions is: would a 6800 RPM fuel cut lead to rod bolt failure. The general consensus is no. You may contend otherwise. I have no experience with a LT1 over the long haul with a 6800 RPM fuel cut. Now on the supercharged counter point. The LT4 puts out approximately 560 WHP. The OEM, added forged pistons with associated ring package, more cooling, a new block made out of different material, new valves, way better fueling (list off the top of my head). Even at that I think it is debatable if a LT4 would last longer than a LT1 NA stock vs stock. Ergo, a LT1 with a supercharger tossed on is going to be decidedly less long-live with the same performance envelope over time. a) I personally know LS1 failures due to piston / ring under boost. b) I know of NO LS1 bottom end failure due to a NA build with 6800 RPM fuel cut. Outside of the know failures of putting it into the wrong gear and letting out the clutch. I've already noted LS1 failures due to high lift cams (valve springs, lifters, pushrods and rocker trunions). So to argue that( reasonable RPM on a reasonable lift) cam is worst than boost, where there are KNOW failures, renders the theoretical point moot. Prima facie boost hurts engines... whatever the reason. My experience ends with the LS1 (yes the 1997 to 1999 rod bolt was a problem). Quote:
04-20-2017, 08:11 PM | #79 |
Thanks Procharger for that post. Great information.
To clarify on my about "posting a link" (if it wasn't already clear), I wasn't calling anyone out for proof. I am genuinely and sincerely interested in reading more about this topic, if that is available. You've given some very interesting insight into an issue I had not heard (read) of before. |
04-21-2017, 04:06 AM | #80 | |
04-21-2017, 08:25 AM | #81 | |
It's been fun, done with GM.
2018 Camaro ZL1 (SOLD) - Blown Airbags 2017 Camaro SS F1FTY Member Journal (SOLD) - Bad Motor |
04-22-2017, 01:15 PM | #82 | |
Drives: 2018 ZL1 A-10 Join Date: Jan 2017
04-22-2017, 01:32 PM | #83 | |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
04-22-2017, 02:01 PM | #84 |
