10-11-2018, 04:50 PM | #15 | |
I also plan on under coating it but don't know where do get it done, like there is so much under the car and I don't want sticky ribber stuff everywhere. 2. On my Subarus I went from a 205/55R16 to a 195/60, it seems that most people are running a 245? I could run a 265/40 19 or a 265/45 19 but those are pretty expensive. I am pretty well versed on tire sizes and have spent a lot of time with a tire calculator. Right now I'm trying to decide between a studless ice and snow or a performance winter tire, I know the performance tire isn't going to do as well on snow but with the 1LE suspension and being a 2 door sports car it might be a better choice... |
10-11-2018, 06:32 PM | #16 |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
Definitely performance winter... unless you live somewhere where there's snow on the road most of the winter. They are very good in the snow and surprisingly decent on cold dry pavement. The LT1's torque is likely to eat up a softer pure snow tire and they suck to drive on if there isn't snow on the ground.
10-12-2018, 07:06 AM | #17 |
Drives: 2018 SS 1LE Join Date: Sep 2018
So how bad does the Camaro pick up salt and grim on the under body? In MD they way over salt the roads. I have looked under my previous cars (Mitsubishi Evo) and it is mainly the drive line components that start looking pretty bad.
I am probably going to try and hit the car washes to get an under body spray during the winter as much as I can. Only thing is I think I have to go to a manual car wash. My 1LE manual says not to use an auto car wash. |
10-12-2018, 10:02 AM | #18 |
The manual means not use one of those washes that pulls the car thru, not the stall you park under and the arm rotates around car.
10-12-2018, 02:18 PM | #19 | |||
What tire? Quote:
10-12-2018, 02:21 PM | #20 | ||
I still wouldn't... it's a brand new car, and I usually do a better job with the pressure washer anyway... I have wondered what you are suppose to do to the fuzzy stuff under there tho? |
10-12-2018, 08:12 PM | #21 | |
Without a spacer you'll have some amount of mismatch on the spacing, although with 9.5" wide 20mm offset wheels the rear would only stick out ~5mm more than stock. I'm being picky and spending ~$200 more for spacers and studs to make the square setup work without the rear sticking out more than stock. If you don't go square I'd probably go with regular SS wheels w/performance snows or even the stock sized Pirelli snows if you won't be driving in snow that much and don't have steep hills. Stock sized setup w/Pirelli snows would be around $4k though, not cheap. |
10-14-2018, 02:19 PM | #22 |
Do these cars use special TPMS that tell temp? where does the temp sensing come from? Should I just let the shop put on whatever TMPS ot get ones from the dealer?
10-15-2018, 10:02 PM | #23 |
Razzi
Drives: 99 Monte Carlo Z34 Join Date: Jul 2008
Does anyone see an issue with this square setup?
CURVA C300/ Rim Diameter: 19 Rim Width: 10 Offset: 30 Bolt Pattern: 5x120 Hub Bore: 73.1 Front Setup Rear Setup |
10-17-2018, 03:54 AM | #24 | |
10-17-2018, 01:43 PM | #25 |
Razzi
10-17-2018, 01:59 PM | #26 |
I have the same size wheels, 265/40/19s as they were cheap... prolly use 275 or 285 after the 265s are worn out.
You'll need 7mm spacers and .5" longer arp wheel studs with .25" of the nub cut off or studs with threads all the way to the end. You can also use lug nuts with 2" length, the .25" cutoff is to fit Mcgard splined lug nuts. This allows stock wheels w/o spacers to be used w/o changing wheel studs back to stock, but the stock lug nuts won't fit as they are too short. Hub bore doesn't look right though. MRR has Camaro specific wheels that'll work... I think the spec is for Corvette w/30mm offset, any of the PF series will work, so will the new ZR1 replica wheels. |
10-18-2018, 07:40 PM | #27 | |
Razzi
Thanks for your help on this learning more and more about wheels as i'm researching this. I now know about Hub Bore, looks like a 73.1mm to 66.9mm Hub Centric Rings Would fix this issue, they also make them custom out of aluminum. I love many of the MRR wheels however they tend to be expensive for a winter set of wheels. Also unless you go with something like the FS01 you can't get a square set that would work as most are in the et20's or et40's. I want to be able to rotate the tires as they'll be on the car for 4-5 months out of the year. |
10-18-2018, 09:36 PM | #28 | |
They do have the ZL1 Vette wheels in 19x10/30mm, they are the same price as the FS series at 40% off. I almost went with them as the ZR1 wheels look pretty cool. I think about $1400/set... The whole spacer thing is a pita, but the wheel studs only have to be done once. If you want to go for it the arp .5" longer studs are 100-7736 and the spacers are from motorsport-tech.com. Disclaimer: I have NOT mounted my snows yet and can't confirm any of this will work, what the results will be, or any warranty implications. As far as I can tell this will get you closest to the stock 1LE wheel's outer edge in a square, rotatable setup. I have a hard time believing the Michelin PA4s will go anywhere near 30k miles on these cars and they have a 30k mile warranty. |
