Vararam
Old 09-24-2018, 07:10 PM   #1
LETHAL2SS
LETHAL2SS's Avatar
Drives: 2011 Camaro 2SS
Edelbrock E-Force guys, I need your help
I’ve got an old style blower on my car, been on it approx. 10,000 miles, I’ve started getting some oil around some bolts and the snout, I have a video and I will get some pictures to show what I’m talking about, but I’m wondering how/when to change the oil, and if this is something I should be worried about?
(Hard to get pictures as it’s already dusk.)
2010 Camaro 2SS-Mods: Nightfury cam, CNC ported LS3 heads, CNC ported TB, Ported Intake, RX Catch Can, MGW Short Throw Shifter, Mantic 9000 Clutch, TSP 1 7/8 headers, catless NPP, BMR trailing arms, MMR Z/28 Reps 20" gloss black. SOLD
2011 Red Jewel Tintcoat 2SS-Mods: Edlebrock E Force S/C w/ 3" pulley swap,Texas Speed roller Boost Cam 227/235, 641"/649", 114 LSA, PRC Ported Heads, Ported TB,ARH 1 7/8 headers, McLeod RST twin disk 1000 hp clutch, ZL1 Fuel Pump, 620whp
LETHAL2SS is offline   Reply With Quote
Old 09-25-2018, 04:58 AM   #2
adrwhi
MonstaBGP
adrwhi's Avatar
Drives: Shadow
I have also had the same problem, it turned out the hole was stripped somehow and wouldn't tighten. Ended up putting a hellicoil in there. So far so good. Ill keep you updated.
adrwhi is offline   Reply With Quote
Old 09-25-2018, 10:50 AM   #3
LETHAL2SS
LETHAL2SS's Avatar
Which hole are you talking about exactly?
Old 09-25-2018, 11:52 AM   #4
sscamaro
sscamaro's Avatar
Drives: 2010 2SS, 2017 Silverado LTZ
I just looked at mine, which has 50K miles on the S/C and is perfectly clean. It was installed in Sept. of 2010.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
sscamaro is offline   Reply With Quote
Old 09-25-2018, 04:35 PM   #5
adrwhi
MonstaBGP
adrwhi's Avatar
Drives: Shadow
The exact same hole you are having a problem with. The one with the screw.
Old 09-26-2018, 11:37 AM   #6
oachalon
Drives: 2010 Camaro 1SS
I had leakage between my supercharger cover and the supercharger itself. I replaced the gasket and Edelbrock gave me new longer screws. The old ones worked themselves loose.
Mine was one of the original kits as well.
2010 1SS/RS LS3 M6
Edelbrock E-Force Supercharger, 3.00" Pulley, Roto-Fab CAI, Stainless Power LT Headers, LPE Dual Fuel Pump, ID850's, Custom Grind Cam, Katzkin Leather/Suede Interior 630RWHP mustang dyno.
oachalon is offline   Reply With Quote
Old 09-26-2018, 01:03 PM   #7
LETHAL2SS
LETHAL2SS's Avatar
Did it make a noise as well? I believe that's whats happening with mine but it's also making a squealing noise when its under load
Old 09-26-2018, 06:57 PM   #8
adrwhi
MonstaBGP
adrwhi's Avatar
Drives: Shadow
Do you have a part number for those screws?
Old 09-27-2018, 07:52 AM   #9
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
Its a common issue. Just remove a bolt and buy some a little longer locally.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000,
realcanuk is offline   Reply With Quote
Old 09-27-2018, 09:30 AM   #10
oachalon
My sound did change some as air was escaping from the supercharger lid. I do not have the part numbers, this was done probably 6 years ago. As realcanuk said just look for longer screws.
I looked in my emails and this was their response:
We have added longer bolts to the lid to give better clamping in that
area. We could also have him put some silicone in the dowel hole that
is under that bolt to hedge against leaking.
Please torque the bolts to 8 FT LBS
2010 1SS/RS LS3 M6
Old 09-27-2018, 10:30 AM   #11
LETHAL2SS
LETHAL2SS's Avatar
Should I replace the gasket as well when I do this or did you just replace the screws?
Old 09-27-2018, 01:45 PM   #12
oachalon
Edelbrock sent me the gasket when they sent me the screws, so i replaced it at that time. Going on 6 years now without any issues.
2010 1SS/RS LS3 M6
Old 10-01-2018, 09:52 AM   #13
LETHAL2SS
LETHAL2SS's Avatar
any part #'s???
Old 10-02-2018, 07:21 AM   #14
LETHAL2SS
LETHAL2SS's Avatar
UPDATE: Spoke with Tony @ Edelbrock yesterday afternoon, He gave me all the info needed and is even sending me a rebuild kit free of charge even though I'm out of warranty! I'll be taking the S/C off as soon as I get the kit in and resealing the lid and servicing the fluid, I'll follow up here when I inevitably run into anything Interesting as he said most of the early built S/C were not tapped for the longer bolts.
