07-20-2018, 08:37 PM | #1 |
Agent Orange
Drives: 2022 ZL1 Join Date: Aug 2016
How different are the 2013 vs 2014 ZL1 superchargers?
I have a 2013 ZL1 and the bearing just went out on the snout pulley and I went down to a Chevy dealer and instead of replacing the snout piece, they were replacing the entire supercharger under the extended warranty. Why not just replace the snout? Is there just a big difference between the 2 superchargers altogether?
07-20-2018, 09:29 PM | #2 |
Drives: 2013 ZL1 Join Date: Dec 2012
Chevy only replaced the entire supercharger under warranty. They never just did the snout
'13 ZL1
'06 TBSS '98 TJ '87 GN |
07-21-2018, 11:55 AM | #3 |
Drives: 2013 ZL1 Join Date: Jan 2017
Now that they have replaced the supercharger, go straight to a reputable shop and have a solid coupler installed!
https://www.lingenfelter.com/product...l#.W1NlddJKiUk |
07-21-2018, 12:19 PM | #4 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
07-21-2018, 12:32 PM | #5 |
GM stopped putting solid ones in and went back to spring loaded....
'13 ZL1
07-21-2018, 01:29 PM | #6 | |
https://www.camaro5.com/forums/showthread.php?t=487501 |
07-21-2018, 08:14 PM | #7 |
Drives: 13ZL1 Join Date: Dec 2017
My supercharger was replaced last week of May this year has the solid coupler.....
07-23-2018, 09:46 PM | #8 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
I'm still running the original SC with the spring loaded coupler...several track days... no issue
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
07-24-2018, 08:13 PM | #9 | |
https://www.camaro5.com/forums/showt...=524868&page=2
'13 ZL1
07-24-2018, 09:36 PM | #10 | |
07-25-2018, 10:51 AM | #11 | |
Even the solid design has changed to a "not as solid" piece.
'13 ZL1
07-25-2018, 11:31 AM | #12 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
It's my understanding, that the original spring loaded design was replaced with a solid coupler for a while, then they went back to a spring loaded design, but the second spring design was also packed with grease/lube.
Since the entire SC assembly is considered a field replaceable unit that is manufactured by Eaton, I doubt that there would be a GM TSB that would show/list the inner details of the coupler. That info would probably have to come from Eaton, not GM. |
08-03-2018, 06:47 AM | #13 |
Drives: '16 Camaro SS 6 spd manual transm. Join Date: Aug 2012
The most important change is that the '14 & '15 had a revision improving their S.C. for the rest the only difference that you would see is the change on rear lights and rear diffuser design that's it.
'16 Camaro SS
Prior cars: '14 Corvette C7 Stingray Z51 '14 Camaro ZL1 w/. Recaro seats '11 Mustang GT 5.0 w. track package '02 Porsche 911 Carrera '05 Infiniti G35 coupe sport |
08-03-2018, 11:33 AM | #14 |
Drives: 2013 VR ZL1, M6 Join Date: Nov 2017
My blower was replaced right before I purchased my car in Nov 2017. I have the newest version with the updated spring coupler, and it has been problem free so far.
#3257 | 485whp 526wtq | K&N 63-3079 | Gates K080660HD (Green Belt) | ACDelco UPF48R | ZL1 Addons Wicker Bill | Mild2Wild
Thread Tools | |
