03-19-2021, 02:14 PM | #1 |
BLUPRINT_1LE
Drives: 2022 Rapid Blue SS 1LE Join Date: May 2017
Fuel It Bluetooth Analyzer. Bluetooth Only
I am selling this Fuel It Bluetooth Analyzer. Bluetooth Only adapter. I originally purchased it for the 6th gen camaro but I get an error code on the 6th Gen and need a raw signal output. Apparently the 5th gen are not impacted by this. This is completely brand new and I installed today and removed it when i got the CEL.
The was an easy plug and pay for the Lethal Garage FF Kit and DSX FF Kit for the Camaro. I am willing to part with it for $135($209 from manufacturer) shipping included. https://www.fuel-it.com/bluetooth-flex-fuel-analyzer/
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- Last edited by Blackmonba6Gen; 03-19-2021 at 09:25 PM. |
03-22-2021, 03:44 AM | #2 |
Do you have kinda of instructions for this??
Orange Krush II
03-22-2021, 07:30 AM | #3 |
BLUPRINT_1LE
I don't have instructions for this since the package I received from the company didn't come with any instructions. The particular product is literally plug and play. I seen another user on the Camaro5 forums which use this product and assumed it worked on the 6th gen but they have a different unit for the 6th gen.
Here is the post for another camaro5 owner. It's really easy to install. The other wire is not needed I never used it but they sent it to me. If you already have E85 flex fuel sensor this will give you Bluetooth functionality to read your ethanol from your phone. https://www.camaro5.com/forums/showthread.php?t=549851
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- |
04-14-2021, 01:15 PM | #4 |
Drives: 12 camaro ss Join Date: Apr 2016
still available?
08-01-2021, 11:57 PM | #5 |
Drives: 2010 Camaro SS Join Date: Jul 2021
Will this work on 2010 camaro ss & is it still available
