06-11-2017, 05:55 PM | #1 |
Drives: Car Join Date: Sep 2014
New hood tweaks
Was hoping you guys can help out. Just put on a new carbon fiber hood from carbon creations. It fits pretty well but I need to do some minor tweaking that I can't seem to figure out. When looking from the side above the wheels the hood is taller than the fender. It almost looks like it curves. The back near the windshield is actually down below the fender while the front in relation to the bumper and fender is pretty flush. I've messed with it a good bit and can't seem to find the solution. Any tips?
06-13-2017, 03:22 PM | #2 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Dec 2016
It's very likely a production defect, probably not much you can do about it other remanufacturing what was likely an expensive piece. The Carbon Creations unit we installed on our Vette needed the entire hinge mounting location cut out and rebuilt in order to mount to the car. Unfortunately, It happens.
06-15-2017, 09:19 PM | #3 |
Drives: 2010 2SS/RS Join Date: May 2010
This makes me glad I bought a great used ZL1 CF hood. Plug and play!
LME built LSX427 w/t all Callies internals| AGP 65/65 TT | Holley Sniper Intake | Brodix BR3/LME custom ported | LME custom cam | Pro EFI 112 ECU | ID-1700x | NGK BR7EF | AGP's-Fore Triple Fuel pump | Monster LT1-S Triple | ZL1 3.23 diff, CF driveshaft, ZL1 axles | Hurst Line Lock | MGW Retro Short Throw | Pfadt solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Ground Control camber/caster plates | Accelerated Racing Solutions tuned| God is too good! I don't deserve it, but I sure will accept it!!! |
06-16-2017, 05:41 PM | #4 |
Drives: 2016 1ss Camaro Join Date: May 2016
we require professional installation by a custom bodyshop on all parts and it may be a simple adjustment issue or maybe bumpstop or the whole hood may need to be adjusted not sure but i would take it by a local shop to have them check it!
Andrew Bettridge
Account Manager Extreme Dimensions 1-714-278-8000 EXT 17 andrew.bettridge@extremedimensions.com |
06-16-2017, 06:20 PM | #5 |
Been dealing with your very helpful customer service and we are working on figuring it out. The hood is not able to have the oem washer nozzles at the moment because of the clearance either.
06-16-2017, 06:23 PM | #6 |
oh ok good to hear and i think andrew was helping you out the other day! he also has a 5th gen camaro !
Andrew Bettridge
06-17-2017, 04:43 PM | #7 |
06-21-2017, 01:52 PM | #8 |
good to hear!
Andrew Bettridge
