07-17-2015, 09:29 AM | #1 |
Drives: Car Join Date: Sep 2014
ACS T5 Splitter
With this splitter, has anyone just bought the black primer color and ran it? Does it hold up well? If I were keeping the splitter a black like the factory diffuser should I just get the satin black for the extra money?
07-17-2015, 09:37 AM | #2 |
Drives: 2013 Camaro 2SS/RS Join Date: Jun 2013
Painted mine with black primer and then matte black trim paint....looks great and has held up fine since the spring. If you go that route sand with a fine grit sandpaper and leave for 24hrs before painting. That's what Joseph at ACS told me to do.
2013 Black 2SS/RS : Go: M2W, BMR Trailing Arms & Bushings, CAI Intake/Scoop, Ported TB. Stainless Power Headers, RDP Tune Show: 1LE Strut Tower Brace, ZL1 Spoiler, ACS Rockers & Splitter, Niche Misano Rims. |
07-17-2015, 10:25 AM | #3 |
Ok cool, from what I'm reading they come in a black primer?
07-17-2015, 11:04 PM | #4 |
Drives: 2013 camaro ls; 2005 rx8 Join Date: Mar 2013
Ive bought three splitters from them, 2 were gray primer and i think the third was black...but like above, i sanded then just used flat black spray paint...havent had any problems...
07-19-2015, 09:11 PM | #5 |
Ok cool so the contest is to sand with fine grit paper (what grit?) then paint. I noticed one if you used matte black and one used flat black? I was thinking on satin black...? How many coats and did you clear coat?
03-21-2016, 12:17 PM | #6 |
Sorry...never responded to this. They come black primer but need to be painted as the primer will fade. I used I think 2000 grit and painted with matte black trim paint from Canadian Tire.
03-27-2016, 05:59 PM | #7 |
INFECTED
Drives: 2011 1LT Synergy Green Join Date: May 2011
I got the T5 Splitter from ACS . I went with getting it painter satin black . I wanted a little shine to it only because Matt black & flack black show scratches so easy . I also got the side rockers and rear extentsions all done in satin black . they hold up great and shine just enough to look clean . I couldn't be happier. My ZL1 spoiler is matt black and I regret it so much because it shows scratches easy. Also one thing I did to the splitter & rockers on the edges is went to Auto Zone & bought the trim edge stuff for the door , the small gauge and I went and put it on the bottom edges of them , clean look and protects them from scrapes.
04-14-2016, 09:31 PM | #8 |
Drives: 2013 Camaro 1LT RS Join Date: Aug 2015
How hard is this splitter to install? I'm looking at getting a splitter for my RS and haven't found one that I really like for the V6 front end.
04-15-2016, 07:31 AM | #9 |
Drives: 1969 SSRS Camaro 2013 1LS Camaro Join Date: Jan 2013
I have wanted a ACS T5 for some time now but could not pay the extra $100 for shipping that online resellers wanted . So I went on a vision quest and found it for $273.43 shipped to my home after using the $25.00 off coupon on the website. I ordered the black primer one and will paint it with a clear satin paint , will post when done this weekend as it just arrived via fed ex yesterday. Purchased at Southerncarparts.com on 4-9-2016 arrived to South Jersey 4-14-2016
04-16-2016, 08:47 AM | #10 | |
Drives: 2014 2SS/RS - SIM Join Date: Apr 2014
04-16-2016, 04:44 PM | #11 | |
Drives: 2014 ZL1 Join Date: Aug 2015
04-16-2016, 07:44 PM | #12 |
Drives: 2015 1LS Join Date: Jul 2015
04-16-2016, 08:25 PM | #13 |
Drives: 2010 IOM 2ss/RS Join Date: Sep 2009
I sprayed my ACS splitter with black paint didn't hold up well at all. now I use plastidip holds up great and if a spot needs to be redone, I just spray that spot easy!
Turbonetics running 8lbs boost at 700rwhp tuned by Hi Rev, installed by K&M w/cat-muffler delete, ACS splitter, Fesler GFX, MPD1 spoiler, Custom painted Rally stripes, Cordon CR1 wheels 275/315s, Hotchkiss comp sways and end links, Barton shifter
04-16-2016, 08:56 PM | #14 |
Install is very easy. Well for me at least. Just make sure you have the correct size drill bit to not over drill the holes
