03-02-2010, 09:41 AM | #1 |
Drives: 2016 SS Convertible Join Date: Jun 2009
Anyone use ADM Performance X Pipe?
Has anyone got the ADM Performance x pipe for use with their stock exhaust? http://www.admperformance.com/produc...55&product=120
I'm just wondering if it can be used w/ stock pipes and if anyone has used it what their thoughts were? If this can't be used with a stock system, does anyone know of an x pipe that can be added to the stock system? I pretty much broke the bank getting the car so I'm looking at an inexpensive way to add an x pipe. Thoughts? Thanks in advance! |
03-02-2010, 09:49 AM | #2 |
Drives: '69 SS Convertible Join Date: May 2009
http://www.camaro5.com/forums/showthread.php?t=64964
Info, pics, video.....should be a good starting point for you.
-2010 Camaro 2SS | M6 | VR w/White Stripes | 1 3/4" KOOKS - 3" Magnaflow | LPE 3.91 gears | ADM tuned | Halltech w/ADM Scoop | Spohn/BMR Trailing Arm/Toe Rod | BC Coilovers| Pedders FE4 ZL1 swaybars | Cradle/Diff/Radius Rod bushings | VMax TB | Morimoto Projectors | MGW shifter | Red Calipers
Build Journal |
03-02-2010, 09:59 AM | #3 |
Thanks! I'll check it out.
03-02-2010, 01:47 PM | #4 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
It looks exactly like the Magnaflow version, but costs less.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
03-02-2010, 02:09 PM | #5 |
Drives: 2010 IOM 2ss/RS Join Date: Sep 2009
yep pretty much looks like the magnaflow one i just had put on my car, price seems right too. i assume mine was the same size diameter but not sure.
03-02-2010, 05:26 PM | #6 |
Wow wonder why its that much cheaper anyone know anything about these Im very interested unless there is some negative feedback
Loving this car!
03-02-2010, 06:26 PM | #7 |
Drives: 2010 Camaro 1SS/RS/M6.....no longer Join Date: Dec 2009
It appears to be a 3" X Pipe. I BELIEVE the factory is 2.5". I THINK this is the one guys are using with stock exhaust:
http://www.summitracing.com/parts/MPE-10791 |
03-02-2010, 08:08 PM | #8 |
Drives: Anything I want Join Date: Oct 2008
It was originally made to replace the h pipe in the C6 Z06.We discovered that the camaro has almost the exact same pipe spacing and works just fine,it will need to be welded in,as all need too.Any muffler shop can expand your 2.5 " to 3" and it will work no problem.Or custom transitions can be purchased for a 100 percent smooth transition,everybody makes them.
It is constructed of 304 stainless and is identical to the magnaflow. Hope this helps. We also sell the same magnaflow that summit racing sells,for the same price. |
03-02-2010, 10:21 PM | #9 | |
Search Ninja
03-03-2010, 07:46 AM | #10 |
All thanks for the info. Looking to do the x-pipe in the near future and just wanted to make sure this one would work.
03-03-2010, 07:57 AM | #11 |
Resident Engineer
Drives: 2010 Camaro SS, 1988 GMC S-15 Join Date: Jun 2009
yeah it will work. just have to stretch the 2.5" to the 3" o.d. i personally will use the 2.5" magnaflow one just because i don't want to lose the laminar velocity of the exhaust gas as it expands to that 3" part then build back up when its bottled down through the rest of the 2.5" exhaust. i know it wont make much difference at all (if any) but its just for piece of mind from my fluid mechanics class in college haha
12.68 @ 109: LSR cai, Borla S-type axle-back, Tunes |
03-03-2010, 09:04 AM | #12 | ||
Search Ninja
03-03-2010, 08:16 PM | #13 |
03-03-2010, 08:31 PM | #14 |
Drives: 4 wheels Join Date: Mar 2009
I has the stock exhaust also. What's the advantage over what's already on the car?
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
V8 Camaro Performance Upgrades List | Milk 1027 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 93 | 08-30-2021 05:56 PM |
ADM Performance Stage Two Build... | ADM PERFORMANCE | Forced Induction - V8 | 32 | 01-17-2012 06:25 PM |
Widened Wheel Package from Andy @ ADM Performance | LittleRockCGM | Wheels and Tires Talk Sponsored by The Tire Rack | 45 | 03-22-2011 11:07 AM |
ADM Performance finishes LS9 Cammed 427 | ADM PERFORMANCE | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 5 | 01-10-2010 05:03 PM |
ADM Performance Stage 1 Cam/Downpipes package | ADM PERFORMANCE | V8 Bolt-Ons & Tunes | 19 | 09-21-2009 08:08 PM |
