03-29-2017, 09:42 AM | #15 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
Yup, I can hear mine too if I'm just cruising around with the radio off at slow speeds. Doesn't bother me one bit as I know what it is...and it's normal. The sound tube probably pumps more of the sound in too...
03-29-2017, 11:16 AM | #16 |
Drives: 2017 HBM SS 1LE Join Date: Jan 2017
Off topic....but speaking of this sound tube. Can it be taken off without any problems....even without "upgrading" or changing ANYTHING else?
2017 SS 1LE Hyper Blue Metallic
2016 Yukon SLT White Frost Tricoat 2012 Maxima SV Sport Winter Frost Pearl |
03-29-2017, 11:24 AM | #17 |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
This is more than just direct injector ticking. I'm 1000% used to that. This is something else that has been getting louder over the last 500 miles.
Nevermind. I'll just take it to the dealership. I was more curious if anyone else heard anything similar.
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
03-29-2017, 11:36 AM | #18 |
Drives: 2006 Lexus IS350 Join Date: Mar 2017
Possible exhaust leak thus amplifying the sound?
03-29-2017, 11:48 AM | #19 |
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
Your first video sounded fine, the second one, yes, it sounds a bit like poop. I sat in my garage last night with the engine running for about 10 minutes, revving it every once in a while...i didn't hear what I heard in your second video. Did you open the hood or record from outside the car?
I walked around my car, and if I bent down by the back side of the front wheel, on driver's side, things sounded louder, but still not like what you posted in second video. When you go to the dealer, have them pull up another SS with NPP and see if they sound the same.
03-29-2017, 12:26 PM | #20 | |
I tried to record the sound with my GoPro and with my iPhone, iPhone sorta worked the best with it placed somewhere near the driver's side valve cover and the hood closed. We'll see. I'd rather be overly cautious and have them tell me it's normal than wait until it gets worse.
Old: 2017 SS 1LE
03-29-2017, 01:51 PM | #21 |
Drives: 2SS & GT Premium Join Date: Jan 2017
I have a '17 SS, and I had a '16 SS, they both pretty much sounded just like that...DI is noisy on these LT1's!
03-29-2017, 02:03 PM | #22 |
LIFTER problem, dod engine run compression, will show low psi on bad cylinder
2016 Camaro 1SS, Red Hot, K&N Blackhawk intake, Whipple Supercharger, 3.125 pulley, Kooks 2" long tube headers, High flow cats, secondary cats delete, Mishimoto catch can, P3gauge, Lots of dress-up crap that don't make it go any faster.
Car Journal http://www.camaro6.com/forums/showthread.php?t=490975 SC build http://www.camaro6.com/forums/showthread.php?t=492656 Drive, Ride, Fly It Like You Stole It GO BIG OR GO HOME |
04-03-2017, 10:35 AM | #23 |
so...??? find anything out at the dealer?
04-03-2017, 10:57 AM | #24 |
Swung by over the weekend, a few techs listened to it and they admitted they could definitely hear it, but they suggested to wait until my next oil change to see if anything changes, even though I told them I changed the oil at 650 miles (has 1100 on it now). They gave me the b.s. line of "the parts are still getting used to each other" but I let them know it started doing this about 200 miles ago.
Guess we'll see, but I'm telling you guys, if you heard it, it sounds embarrassing. The only good thing is that it really only happens between 1700 and 2000 RPM.
Old: 2017 SS 1LE
04-03-2017, 04:23 PM | #25 | |
04-03-2017, 04:31 PM | #26 | |
04-03-2017, 05:07 PM | #27 |
Drives: 2015 2SS/RS/1LE Join Date: Feb 2016
Sounds like my old Subaru Direct Injection system on the 2.0 Turbo.
04-03-2017, 08:10 PM | #28 |
Mine is not 1le but did make a ticking noise that i was worried might be a f'd spring or lifter, not as pronounced as yours but similar.. come to find out was a beat down belt tensioner.. just thought id chime in with that.. good luck with your fix..
DMS Flex Fuel-E85
HPTuners Ngauge Roto Fab CAI, LPE Ported/Polished 95mm LT5Throttle Body, PRAY Ported MSD Intake Manifold, SP Coated TSP 1 7/8" Catlless Longtubes Hooker BlackHeart Cat-Back, Mishimoto Catch Can (Which always has some nasty in it) Instagram@Weapon_6 |
