Old 05-10-2020, 07:59 PM   #1
19 2SS
Drives: 2019 camaro 2ss
Supercharger question
As of now my 2019 camaro ss a10 is basically stock (just an axle back exhaust), I’m looking into supercharging it, would it be safe to just straight up add the supercharger to a completely stock ss? Or should I be upgrading certain things before adding the supercharger?
19 2SS is offline   Reply With Quote
Old 05-10-2020, 08:05 PM   #2
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
You’ll find most of us will recommend upgrading your fueling at the same time. All of the typical players (Maggie, Whipple, etc) all say you can run their blower with the stock fuel system, but you’ll have maxed it out and not be able to go any further until you do upgrade it. So, LT4 in tank low pressure pump, LT4 high pressure pump, and LT4 injectors are kind of the minimum you want to do.
Old 05-10-2020, 08:44 PM   #3
19 2SS
Thanks for the input, what kind of dyno numbers would a supercharger alone make?
Old 05-10-2020, 08:45 PM   #4
Joshinator99
Most every manufacturer will advertise 550-600 RWHP with a stock engine.
Old 05-10-2020, 09:46 PM   #5
Kerry
Drives: 2019 2SS Camaro
Been runing a p1sc procharger on a other wise completly stock 19. made 570 wheel. No need to do anything to the fuel, if their was then procharger would recmond it and they dont. I can guarentee procharger and the rest of the manafactures have done lots of testing on their products. How many blown engenies from runing the base programs from these manfactures are out their. I have found none, but maybe they are out their.I will listen to them before anyone else...
On my sons challenger their kit comes with injectors. why because it needs them. If you want to make alot more power than base kits then yes some kind of fueling upgrades will be nessary, depending.
Kerry is offline   Reply With Quote
Old 05-10-2020, 10:05 PM   #6
19 2SS
Originally Posted by Kerry View Post
Been runing a p1sc procharger on a other wise completly stock 19. made 570 wheel. No need to do anything to the fuel, if their was then procharger would recmond it and they dont. I can guarentee procharger and the rest of the manafactures have done lots of testing on their products. How many blown engenies from runing the base programs from these manfactures are out their. I have found one, but maybe they are out their.I will listen to them before anyone else...
Awesome thank you!
Old 05-11-2020, 05:10 AM   #7
Joshinator99
You’re missing the point. You cannot go any higher now until you upgrade fuel, and it’s easier to do when you’ve got the car apart for the blower anyway (especially a PD blower). You also cannot run E85, leaving another 25-30 HP on the table (more at higher HP levels).
Old 05-11-2020, 11:16 AM   #8
Stefano
Stefano's Avatar
Drives: 6th Gen NicKey Camaro & others.
550-600ish is what we have found to be the 93 Octane Gasoline safe limit of the stock LT1 fuel system.
Stefano is offline   Reply With Quote
Old 05-11-2020, 11:32 AM   #9
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
2016 NFG 1SS A8
Options-2SS Leather/NPP
