04-09-2016, 10:52 AM | #71 |
Drives: camaro Join Date: May 2013
OK, guess I will be crawling under my car tomorrow. Hoping for engraved letters!!! BTW, this a big f up from GM. Sure they are doing the right thing, but they are gonna loose a boatload of $ fixing this.
Hyperblue/JetBlack |
04-09-2016, 11:15 AM | #72 |
Drives: Z28 Join Date: Nov 2015
I would recommend the last 6 numbers in the VIN be added to this site. I just noticed a brand new car serial number 143241 was tagged in the recall.
04-09-2016, 12:07 PM | #73 | ||
The Dogfather
Drives: #1 off the line for a customer. '16 Join Date: Oct 2015
Bulletin 30990 (Oil Pickup tube bolt retention)
THIS IS FOR 2016 CAMARO SS / 2SS MODELS ONLY. (Also for 2016 CTS-V's)
I know there is a pretty good size thread however, I figured I'd post this here as I do have the bulletin so it doesn't get lost somewhere in the thread and for people to find it easier. GM updated their dealership network SIS (service info system) over night. I called my dealership and made an appointment for monday morning. Make sure you get this checked ASAP as IF you do have it. It is a LONG and PITA process to implement the preemptive (or simply put, fix) process. It will require them to put the entire engine on a cradle to hold it up and get to work. On average, it's a 9 hour work and not everyone can do it, a gen 6 camaro/ c7 corvette specialized tech is the only one who can. So bank on a couple days at least, IF you have it. Here is the entire Bulletin 30990 in PDF which you can download via my dropbox OR view it via the attached bulletin as PDF here: https://www.dropbox.com/s/x2pefrimju...letin.pdf?dl=0 Also: Glen has posted here: http://www.camaro6.com/forums/showpo...5&postcount=68 Quote:
04-09-2016, 12:09 PM | #74 |
Drives: 2016 2SS Join Date: Dec 2009
How do we check the engraving. Do you have to go under the car or can you see it in the engine compartment?
04-09-2016, 12:12 PM | #75 |
Retired from Car mfrs....
Read the PDF that many of us have put above…
04-09-2016, 12:16 PM | #76 |
The Dogfather
I just made a brand new thread WITH the actual service bulletin and what Glen shared on there so it's much easier for people to see and not get lost in this decent size thread haha.
http://www.camaro6.com/forums/showthread.php?t=447820 |
04-09-2016, 12:26 PM | #77 |
04-09-2016, 12:29 PM | #78 |
The Dogfather
Thank you for the pic Glen and great idea!
04-09-2016, 12:46 PM | #79 |
Drives: 16' 1SS M6 Join Date: Oct 2015
I got the all clear today. Phew. I drove with my gauges exactly like that Glen! Now to get my bumper fixed > : |
Nightfall Grey 1SS 56F Black Bowties
04-09-2016, 01:29 PM | #80 |
The Dogfather
Go to: https://my.gm.com/recalls and enter your VIN. If this pops up, even if you aren't having any issues, you still need to either check the oil pan yourself or have the dealership check to see if the number is engraved or raised. If it is raised, you have to get this done as it will prevent any issues that may or may not occur. If you don't get it done now while knowing it, it will be your responsibility if things go back.
04-09-2016, 02:11 PM | #81 | |
Loves Camaros
Drives: Red '79 Z28, '21 Red Hot M6 ZL-1! Join Date: Sep 2012
Old and new, sharing space!
04-09-2016, 02:38 PM | #82 |
Serial number 146384 in recall whereas 148830 not in recall. So the cutoff line should be around these numbers.
04-09-2016, 02:43 PM | #83 |
Drives: 2016 Black 2SS Join Date: Feb 2016
My serial number is 146389
Camaro 2SS
Black/Jet Black A8, NPP, MRC, NAV Low Gloss Black 5 Spoke |
04-09-2016, 03:12 PM | #84 |
Drives: 1SS Hyper Blue Join Date: Apr 2016
Bulletin leaves me non-plussed as far as identifying whether my car has the issue. It says to remove the "left side front compartment side noise shield", not sure where that is.
Anyone know if the lettering on the pan is visible directly from underneath the car? |
