08-20-2020, 06:08 PM | #15 | |
Drives: 2010 Camaro 2SS Join Date: Jul 2020
08-20-2020, 07:09 PM | #16 |
That will definitely be loud in shear volume, but you will lose that signature Magnaflow 'Deep' tone you like. With that exhaust and your longtubes, think 'NASCAR'. Magnaflow does a very good job of filtering out some of the nastier tones and rasp that other exhausts can deliver. Not saying that will be bad at all, but it will definitely be different than what you have now.
My best advice is to TAKE YOUR TIME and start listening to as many videos as you can until you find something you like. The problem is that bass doesn't translate well to video clips, so hearing this stuff in person is always best. Make sure that you are listening to Camaros with long tubes, but I figure you already know that. With the way our exhausts are designed I would recommend only listening to our cars specifically.
08-20-2020, 07:17 PM | #17 | |
08-20-2020, 07:21 PM | #18 | |
I know Magnaflow makes a very loud exhaust but we really need to figure out what model you currently have installed.
08-21-2020, 07:03 AM | #19 | |
Drives: 2018 1SS M6 Join Date: Nov 2014
The other thought I will put out there, having grown up and lived the majority of my life in the South KC, Overland Park area, is that the low throaty sound the Magnaflows are providing is probably what is keeping you from having regular conversations with law enforcement in that area. I know there are certain parts of O.P. that aren't real friendly about open pipe cars, and there is Leawood, which you would want to avoid all together. But, you probably already know that. Sounds to me that you are at that point of compromise. It's the question of sound volume vs sound quality at this point. |
08-21-2020, 11:11 AM | #20 | |
Drives: Silver 2014 Camaro 2SS Join Date: Dec 2018
2014 Silver 2SS L99 with Roto-Fab CAI, Kooks LT Headers, Kooks Cat-less 3” exhaust, TS Stage 3.2 VVT CAM, Circle D 3200 Stall, E85 Kit, FIC 850cc injectors and Elite Engineering Catch Can. Dynoed at 478rwhp.
08-21-2020, 11:21 AM | #21 | |
08-21-2020, 11:38 AM | #22 |
Drives: 2010 Camaro SS Join Date: Feb 2018
Go to E-85. All that smell goes away. lol. I have a flex sensor and run both and it is crazy how much I notice the smell when running 93 now.
2010 Camaro 2SS/RS - 416 stroker, F1A-94 procharger, BTR blower cam, Big Red race valve, AGP intercooler, Alky dual nozzle kit, ZL1 fuel pump with DSX Aux pump, DSX flex fuel sensor, Bosch 210 injectors, Mcleod RXT1200 clutch, MGW flat stick, Tick Performance Level 3 trans, DSS 3.5 aluminum driveshaft, Strange S60 rear, DSS 1400hp axles, Texas speed 1 7/8 headers, X-pipe and MBRP muffler delete, BMR lowering springs, BMR trailing arms and toe rods, Poly motor mounts, RevShift trans mount instert, rear sub frame braces, Tuned by Joey at Pure Fabrication in Panama City, FL
