02-26-2012, 05:39 PM | #1 |
LS3 Black Widow
Drives: 2012 45th 2SS LS3 and 1968 Mustang Join Date: Nov 2011
Advice on installing a skip shift eliminator on my own?
Hey guys,
Did I quick a search and didn't find anything, although my question is odd. So I've got a skip shift eliminator waiting for me back at home. I'm wondering if it's possible to install the eliminator without a lift? All I've got access to are jackstands and a low profile jack. I'm hoping it'll just be cramped but I can still do it. Also, any advice and tips would be great! Thanks, Chip
02-26-2012, 05:53 PM | #2 |
Drives: 2011 2SS RS, 1968 ragtop Join Date: Apr 2009
I think you can do it. Jack it up in the air to give you a little more room. Oh, and read this first:
http://www.camaro5.com/forums/showthread.php?t=205520
1968 Camaro Convertible LS1, T56
02-26-2012, 06:14 PM | #3 |
Drives: Exige, Miata, Ghia Join Date: Jun 2011
Yup it's easy. Just make sure to install it correctly. It's the plug closer to the front of the car that is a little bit harder to get to because its near the top of the transmission.
02-26-2012, 06:15 PM | #4 | |
Drives: 2000 Camaro SS Join Date: Feb 2010
03-09-2012, 03:03 PM | #5 |
Drives: 2010 2SS RS M6 Join Date: Mar 2011
With the GM GFX on this car I can't drive up (forward) on my ramps anymore (that I used to be able to use on the V6 I had previously) but I was wondering if I could back up onto them and have room enough to install the SKE I got recently from APEX? I'm not at home right now so I can't measure the height of the ramps but they're a standard size and I'm curious if they would raise the transmission area up enough to slide under there and have doable access?
03-10-2012, 05:12 PM | #6 | ||
LS3 Black Widow
It was scary changing my oil with those ramps, haha. I'm going with jack stands next time around. Speaking of, where does everyone recommend I put my jack stands and jack the car up from? Quote:
I wish I had the spare cash right now. :(
03-10-2012, 05:31 PM | #7 |
Drives: cars Join Date: May 2011
Just buy a 1x10 or 2x10 from Lowes and set it in front of the ramp. Instant extra clearance.
03-10-2012, 11:08 PM | #8 | |
LS3 Black Widow
Not sure if that's what the problem the other guy was having with GFX.
03-10-2012, 11:48 PM | #9 | |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
CEL - P1682 | PSU SS | Tuning / Diagnostics -- engine and transmission | 4 | 09-29-2011 07:27 PM |
V6 Skip Shift? | B.A.Brunswick | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 10 | 10-08-2010 10:42 AM |
$26.95 Skip Shift FREE w/ purchase of Hurst Billet/Plus 2 Shifter | Apex Paul | Transmission / Driveline | 9 | 04-23-2010 07:08 PM |
St. Louis, MO Tune Special - Turn off Skip Shift or AFM! | DSteck | V8 Bolt-Ons & Tunes | 3 | 04-19-2010 03:20 PM |
Performance Numbers - Skip Shift | fireresq157 | 5th Gen Camaro SS LS LT General Discussions | 16 | 03-23-2009 12:59 PM |
