08-25-2018, 06:34 PM | #1 |
Drives: Crush ZLE M6 | 2000 Corvette FRC Join Date: Jun 2010
Ceramic coated ZL1 1LE wheels today
I was curious how the satin finish would respond. Had to consult a few local pros who assured me it leaves the wheel finish somewhere between no different—>slightly more shiny.....but essentially the same. Wanted them to be easier to clean after track duty (the only thing I’ll use them for). Figured I’d make a quick thread incase anyone else is wondering about a change in finish afterwards.
Process: 1. Pressure washer rinse 2. Washed with Clean Slate, rinsed 3. Iron X while still damp, rinsed 4. Quick once over with clean slate again, rinsed 5. 90% dried with Master blaster 6. Eraser wipe down 7. Pinnacle Black Label Wheel Diamond Coat applied with foam finger sponge 8. Suede MF to remove (more like buff, this coating kinda rubs in mostly) 9. Black Fire SI02 spray sealant as a topper an hour after coating cured a bit. Also did a fairly thorough full maintenance wash on the ZL1. Foam bath etc etc. My back hurts lol. |
09-01-2018, 09:11 PM | #2 |
Camaros Of Northwest Ohio
When GM replaced my stock wheels, I clayed, ceramic coated, Hydr02'd them. It didn't really affect the mat black finished. They still really clean up nice and it's been well over a year.
What is Clean Slate? Bill
2023 2SS 1LE Red Hot
2016 2SS Black / Black & Arenaline Red (sold) 2023 GMC Canyon Denali 2013 2SS / RS - AGM / Jet Black (sold) 1970 1/2 Z/28 Classic Copper / Tan (sold many years ago) Last edited by wrankin; 09-01-2018 at 09:30 PM. |
09-01-2018, 09:31 PM | #3 | |
Drives: Grandad's C2 L89 Join Date: May 2017
2018 ZL1 1LE sw/PDR
09-01-2018, 09:34 PM | #4 |
Clean Slate is a surface cleanser made by Chemical Guys. It strips wax and sealants but is clearcoat safe. Good stuff as long as you are going to at least seal and /or wax after.
2018 ZL1 1LE sw/PDR
09-01-2018, 10:31 PM | #5 | |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
WipeOut is Chemical Guys' surface cleaner. It removes waxes and oils. Most often used before ceramic coating instead of isopropyl alcohol (IPA), as it is now believed that IPA just pushes the oils around. WipeOut is much cheaper than Clean Slate.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
09-02-2018, 10:19 PM | #6 |
Looks good, now post pics with them on the car!
09-02-2018, 11:31 PM | #7 |
