02-26-2019, 02:39 PM | #1 |
Drives: 2022 Camaro 1SS Join Date: Feb 2019
Engine Oil & Fluids
Hey guys.
My oil change sticker says to change it a bit after 9000 miles (don’t know the exact number right now), I’m currently at around 8100 miles. I’ve recently beat on the engine a bit having some fun and was worried I may have possibly reduced the health of the oil. I know you’re supposed to change your oil every 7500 miles, but is changing it every 5000 miles instead better? What kind of oil do you guys prefer, preferably a “premium” one. Also, I’ve read something about changing your differential fluid, should I be concerned about that? Thank you. |
02-26-2019, 02:55 PM | #2 |
Drives: 2017 2.0 Camaro LT Join Date: Aug 2018
I always change mine every 5k miles regardless better safe than sorry, oem filter and oem recommend mobil1 full synthetic
02-26-2019, 09:36 PM | #3 |
Coopers Camaro
Drives: 18 Flex Fuel LTG Join Date: Nov 2016
I STRONGLY recommend GM Dexos full synthetic only for the LTG..
02-26-2019, 10:39 PM | #4 |
603 Camaros
Drives: 2017 NGM I4 1LT Coupe Join Date: May 2012
Mobil 1 Full Synthetic or the GM Dexos Full Synthetic is fine you can actually find Mobil 1 Full Synthetic GM Dexos Approved fairly easily.
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile |
02-27-2019, 09:53 AM | #5 |
Yes that’s the one ☝️ I use the Mobil 1 full synthetic dexos
02-27-2019, 03:17 PM | #6 |
Drives: 2017 Camrao 2LT RS Join Date: Oct 2017
Curious, I am almost at my 10,000 mile oil change and was thinking of using Amsoil. I am tuned running e85 and bolt on's. Do you still recommend GM Dexos?
02-27-2019, 03:35 PM | #7 |
Drives: 2018 Chevrolet Camaro LS Join Date: Jan 2019
I put Amsoil signature oil and Amsoil oil filter at 500 miles. And again at 2500 miles. And I will continue every 5000 miles.
02-27-2019, 03:51 PM | #8 | |
Coopers Camaro
The last I knew, Amsoil did not pass the d1G2 LSPI tests because of high ash content. I still only recommend GM Dexos for the LTG.
02-27-2019, 04:17 PM | #9 |
Coopers Camaro
The big thing to remember (you guys can do your own homework here), is Calcium and Sodium are big contributing factors for LSPI , and Moly is a LSPI repressor. GM spent a lot of money to understand this, and reformatted Dexos to accommodate.
02-28-2019, 10:42 PM | #10 |
When you say GM, do you mean SPECIFICALLY the ACDelco oil, or can I use Mobil1 too?
03-01-2019, 07:33 AM | #11 |
603 Camaros
You can use anything Mobil1, ACDelco, Pennzoil as long as it's 5w30 really. But GM Dexos Approved is highly recommended for the reasons cooper stated. Like stated the GM Dexos Approved is easy to find has the Dexos Approved logo on the front of the bottle.
03-01-2019, 07:55 AM | #12 |
Drives: 2017 Chevrolet Camaro 2.0 LT Join Date: Apr 2017
I just bought some oil for mine, and noticed a lot more oils have the dexos badge now than i used to see. I change mine every 5k and use a gm delco oil filter and whatever oil is currently on sale that meets dexos requirements
03-04-2019, 05:09 PM | #13 |
I change mine once it says 20% on the indicator. I don't really care the distance once it says 20 it gets changed.
03-04-2019, 07:07 PM | #14 |
603 Camaros
Probably the safest route.
Tags |
camaro 2.0t |
