Old 08-17-2018, 05:20 PM   #1
DetCam
DetCam's Avatar
Drives: 2016 1SS (12/10/2016)
Floor Jack Failure Question
I've got two Harbor Freight Floor Jacks... one of the small aluminum racing jacks, and another "low profile" higher lift unit.
Both jacks worked great for a year or two, and now, the heavier duty of the two gave out on me. It didn't drop my car on me or anything like that, but it quit lifting. I got the back of the car up enough to get the wheels off (barely) and then I could keep pumping (and pumping) without any more lift.
Is this more likely to be a blown seal, which I'm assuming is basically a "throw it away and get another one" repair, considering it's a cheap Pittsburgh jack from Harbor Freight junk.
Or could this be air in the hydraulic fluid that simply needs bled?
DetCam is offline   Reply With Quote
Old 08-17-2018, 09:47 PM   #2
gotroost
gotroost's Avatar
Drives: 2021 Crush ZL1 1LE
With a blown seal I think you would see a leak. Might try new fluid or make sure the bleed screw is tight. Used my low profile one for 8 years now with no issues. Also, did you change something where it reached it's max height?
2021 Crush ZL1 1LE
gotroost is offline   Reply With Quote
Old 08-18-2018, 08:13 AM   #3
Wierd Harold
Drives: 2017 2lt rs
Check the plunger or plungers may be stuck down.Mine looks like a valve spring set up has to be oiled up occasionally
Wierd Harold is offline   Reply With Quote
Old 08-18-2018, 10:30 AM   #4
DetCam
DetCam's Avatar
Hmm, no luck. No fluid has leaked out where I can see it. The springs look like they are moving freely. And nope, I have tried to change anything related to max height. When it quit going up, I wasn't anywhere near max height.
I realized I don't usually lift quite as much weight as that last time. I usually put one jack on each side of the car and lift each side a few pumps at a time.
I think it may be bleeding time.
