Old 11-29-2019, 06:40 PM   #1
Coz3z3
Drives: 2015 Z/28, 2015 1LE
Oil Filter Wrench
For you guys with headers, what oil filter wrench are you using? I'm going to be needing a new one. The one I have barely fits with the headers and is probably about to break. I use Wix Filters too if that makes a difference. Just curious!
Coz3z3 is offline   Reply With Quote
Old 11-29-2019, 06:43 PM   #2
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
I just use this
Sent from my SM-N960U using Tapatalk
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 11-29-2019, 06:48 PM   #3
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
I use one of those crappy metal ones that fit over the end of the filter that you turn with a socket wrench. I don't suggest you use them because they are garbage and eventually stretch, just spinning on the filter.
But since you asked.
InFiD3ViL is online now   Reply With Quote
Old 11-29-2019, 07:17 PM   #4
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Imo... if you need a wrench to remove it then you put it on too tight...
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 11-29-2019, 07:40 PM   #5
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
I like to use the cap wrench, but I follow the instructions on the filter to go only 3/4 turn when installing.
If' you're deforming the wrench, you are over-torquing.
Old 11-29-2019, 08:24 PM   #6
Rons1le
Rons1le's Avatar
Drives: 2015 Camaro 2SS RS 1LE AGM
I use the K&N filter with the hex head on the end.
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
Rons1le is offline   Reply With Quote
Old 11-29-2019, 08:37 PM   #7
Vegas Bound
Drives: 2013 Sparkly Red One
Something like this.
Vegas Bound is offline   Reply With Quote
Old 11-29-2019, 09:14 PM   #8
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM #93
I use a screw driver... no joke. I use the screw driver and a hammer to gently knock a hole in bottom of the side of the filter and let it drain. Once it drains just slide the screw driver in the hole and you can leverage the filter loose. I started doing it this way because the dealer I bought the car from spilled oil all over the exhaust when they changed the oil. Took about 2500 miles for the smell to go away completely. It would come and go depending on how spirited my driving was. I read several threads similar to my issue on here. I’ve changed the oil 2 times now on my own and no oil smell at all.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter.
‘87 IROC-Z Iroc blue. all original unmolested with 50K miles.
Aqua Blue RS/SS is offline   Reply With Quote
Old 11-29-2019, 09:23 PM   #9
mikeman
Drives: 2015 Camaro
If I installed it in the first place, I usually don't have a problem taking it off just with my hands if I have good leverage. I think applying a light coat of oil on the gasket before you put it on helps with this.
mikeman is offline   Reply With Quote
Old 11-29-2019, 09:44 PM   #10
InFiD3ViL
InFiD3ViL's Avatar
Yeah, probably. Sometimes I get OCD about stupid stuff when clearly the industry knows better than me on this.
I have always been paranoid about the filter eventually vibrating loose. Although it has never happened to me and I don't know anyone that it has happened to. But I am not going apesh*t on it. Just hand tightened...and then probably snugged a little more.
Old 11-30-2019, 10:12 AM   #11
Coz3z3
Lol yeah thats why I asked. To get opinions on that type of stuff lol
Usually I am able to. Just since I put the headers on, I can't get my hands in there enough to get a grip.
Thats what I have been looking at, but wasn't sure how well they worked and if they slip often. Thanks!
Wow, never thought of that.
Yeah I do that too. Just after I put the headers on, it has got a little more tight in there and can't get in there enough to really even tighten it or take it off.
Thanks for the suggestions guys!
Old 11-30-2019, 10:26 AM   #12
sscamaro
sscamaro's Avatar
Drives: 2010 2SS, 2017 Silverado LTZ
I use one like that. I always put some oil on the rubber seal.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
sscamaro is offline   Reply With Quote
Old 11-30-2019, 11:09 AM   #13
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
i do the same thing
lemontwist is offline   Reply With Quote
Old 11-30-2019, 02:41 PM   #14
Rock-It Man
That is exactly what I use, but I never go past the recommended amount of turning from gasket contact to fully tight.
While some filters have a fine enough thread to call for 1 full turn, the PF48 is coarser and so the requirement is 3/4 turn. For me, it's hard to do this reliably by hand if I'm lying on my back with the car up on ramps. I can either see the filter or be in a position to turn the filter, but not both at the same time.
So I use the cap wrench. I align the ratchet handle with a reference on the chassis and turn it 270 degree. That is snug but never a problem getting the filter off.
I can't imagine deforming one of these cap wrenches. I have three sizes for various cars, and they are all at least 25 years old.
