08-10-2013, 05:26 PM | #1 |
Drives: 2016 Corvette Stingray Z51 Join Date: Feb 2013
Convertible rear seat removal
Would anyone with a vert know how to remove the rear seat? I can get the seat bottom out no problem but I can't seem to find a way to remove the seat back. Thanks for any help.
08-10-2013, 09:03 PM | #2 |
Happiness is.....
Drives: '13 2LT Convertible, '56 F100 Join Date: Jan 2013
The service manual says (after you remove the bottom seat cushion):
1. Using a flat bladed tool, release the seat back retainers through the access holes located between the seat back cushion and the rear end trim finish upper panel. 2. Fold the seat back cushion down and line up the flats on the hinge pins with the slots on the hinges. 3. Pull the seat back cushion upward to remove it from the vehicle. It appears there are two retainers and they are located at the top rear of the seat back cushion, each one is centered on the left or right seat. Hope that makes sense.
I was young and had money once. Bought an old truck and that was that.
08-10-2013, 09:09 PM | #3 |
Drives: 2013 rs/ss Convertible Join Date: May 2013
Like was said above the two retainers are about 6-8" in on the top of the seat, I used my fingers to pull the seat forward and stuck a flat head screwdriver in to pop the retainers. There is a good thread with pics and a vid for the removal if you search "sports bar".
Good luck |
08-10-2013, 09:10 PM | #4 | |
Here is a youtube vid also might help |
08-10-2013, 09:17 PM | #5 |
Thanks for the help. I posted this in another section and received the info there too. Got it taken care of. Simple once you know the secret.
Tags |
convertible, rear seat removal |
Thread Tools | |
