08-12-2019, 11:56 AM | #1 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
Goodyear Supercar 3 Tires: Early vs. New Production
I saw somewhere on here that it was mentioned that the GM spec SC3 tires for SS 1LE/ZL1 were tweeked at some point from their initial production. Anyone know anymore about this?
At first, when reading what I did (where ever I did), I didn't think much of it. I recently put on a set of 2019 SS 1LE take off tires on my 2017 SS 1LE and noticed a minor aesthetic difference and also that the tires seem to be a little softer. The aesthetic difference is that the sidewall/rim protector area is a little more pronounced on the newer tires. The softness I noticed before mounting the tires I didn't think much of it as they were "brand new" (literally only a hand-full of miles on them from the 2019 car they were taken off of). Doing a time trial event weekend on them, during and after (cooled-down, in the garage) the newer tires feel softer and sticker than the versions that came on my car. I am able to say this because I only put the 2019 take-offs on front, leaving the older tires on the rear. I don't feel that I've done enough to the old tires to have them effected by ozone, UV or heat-cycling enough to produce this difference in tread softness/stickiness, but maybe I am wrong. Car has less than 10k miles on it, it stays in a garage when not being used and the rear tires have been through the equivalent of 6 track days. On track, I can't say I noticed any significant difference in grip, but I will say the car felt, in a few corners, a bit more loose mid-corner than what I remember on the track previous. However, I did improve my driving through the particular corners compared to a few months ago, when I was on all older tires. Old/original tires are DOT 5016 and the 2019 take-offs are DOT 2518. Very possible the old tires are just that: older, but since there was mention of a compound change, the sidewall/rim-protector area is physically changed and Goodyear has extended sizing options significantly, with those version having a different tread depth, I thought I'd bring this up to discussion... Pictures are DOT 5016 (top) and DOT 2518 (bottom). Larger sidewall area can be noticed by the larger "ridge between the tread and ruffled circumferential band |
08-12-2019, 01:57 PM | #2 | ||
OK, so I found the post I was thinking about:
and a bit of information: Quote:
08-16-2019, 07:11 PM | #3 |
Drives: 2016 1SS Join Date: Jun 2018
Very interesting. Thanks for sharing. Wonder if they went with a softer compound and a little heavier sidewall?
My older SC3's are wearing incredibly well - quite a few sessions on them and plenty of life left. Maybe they are trying to squeak more grip out of the new revisions? Been eyeballing the old stock Tire Rack tires - they have front and rears now and they are really cheap. Hard to pass up regardless of any improvements that have been made. |
07-05-2020, 09:11 PM | #4 |
I've used the old 2016 & 2017 stock from Tirerack and new Goodyear stock from the Goodyear wearhouse and there is no difference on track.
07-06-2020, 08:40 AM | #5 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Old tires on the rear with the new tires up front is going to exaggerate any differences, and after 10k street miles plus half a dozen track days I think OP's rear tires would have lost half a step or so from what they once were. Midcorner looseness is probably the best clue here.
Norm
'19 WRX 6M (the family sedan . . . seriously) |
07-06-2020, 09:37 AM | #6 |
Drives: '19 ZLE, S54 E36M3 Join Date: Feb 2018
Just ordered a set of new 3Rs. The pricing on the old stock was tempting, but 2017 date code was older than I was comfortable with since I'm heading to VIR with it next month.
07-06-2020, 11:57 AM | #7 | |
07-13-2020, 05:24 AM | #8 |
I've been using the G3R and G3 old stock with no issues. Current pricing for a set is about $715 after rebates
07-14-2020, 12:07 AM | #9 | |
Drives: '19 SS 1LE/'19 Rubicon/'20 AT4 Join Date: May 2015
thanks! matt |
07-14-2020, 06:19 PM | #10 |
So far I've only got 3 track days on the 3R. Wear is great with my 19" 305 square setup due to being able to rotate to any corner. I've seen as much as 4.5 seconds a lap faster on some tracks. Last track I did was about 3 seconds faster. The square setup handles great.
