08-02-2019, 10:24 AM | #1 |
Drives: 2017 Camaro FIFTY 2SS Join Date: Jan 2017
Aluminum Pedal Kit - OEM
I was wondering if anyone here has purchased the aluminum pedal kit from GM (OEM Kit). I received mine, and the box appeared to be sealed from the manufacturer.
The issue/concern that I have is that the brake pedal cover appears to have wear on it, in the form of light scratches throughout the entire aluminum plate. The accelerator pedal does not have any of those marks. I reached out to the vendor and they told me "its totally normal and every one is like that" and "its from the manufacturing process". I find that odd since the accelerator and brake pedal plated are the same material. Has anyone experienced this? See photos. |
08-02-2019, 10:39 AM | #2 |
Drives: E92 BMW M3 Join Date: Oct 2012
Hmmmm...that does not look like a new pedal at all. Sounds like a BS explanation too.
J-Rod Built and Matt@FSP Tuned |
08-02-2019, 11:21 AM | #3 |
I ordered a manual Sport pedal kit for my 2016 SS and all parts were okay. I left them on it when I did trade in for my used 2017 ZL1. The marks may have been done during the manufacturing process if the box wasn’t opened before you got them.
08-02-2019, 11:25 AM | #4 | |
08-02-2019, 12:56 PM | #5 |
Yeah it does seem strange! See if you can send it back and order another kit! I ordered mine from a dealers parts department.
08-02-2019, 01:00 PM | #6 |
Matter of fact looking at the pics my clutch pedal had some streaks like the ones on the brake pad. I didn’t think too much about it I guess because you couldn’t see them being under the dash at the floorboard.
08-02-2019, 01:03 PM | #7 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
My ZL1 1LE was exactly the same when it came in off transport, I thought it was kinda weird but have never thought about it again until now.... thanks lol (only one pedal was scratched up, the brake or clutch i can't remember)
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap Last edited by ICTsccaCamaro; 08-02-2019 at 01:26 PM. |
08-02-2019, 01:08 PM | #8 |
Yeah ICT I guess I need to look at mine on my ZL1 now!
08-02-2019, 01:26 PM | #9 |
Drives: 2002 z28, 2018 2ss 1LE Join Date: Sep 2012
Silly question but how do these mount ? Do they mount on top of the pedals with tape/glue or are they bolted on ?
08-02-2019, 01:31 PM | #10 |
Drives: 2017 Camaro 1SS, 2023 Colorado Z71 Join Date: Sep 2017
The entire gas pedal assembly is replaced, and the brake pedal face (and clutch if manual) are attached by a piece of rubber wrapped around a piece of metal on the pedal, and are removed from that piece and replaced
2017 1SS, Summit White, Black 2SS Interior, MRC, NPP
2023 Colorado Z71, Nitro Yellow |
08-02-2019, 03:24 PM | #11 |
Sorry to open that wound again brotha
08-05-2019, 11:33 PM | #12 |
Does anyone have pics of their installed pedals to compare to mine??
08-05-2019, 11:46 PM | #13 |
WoW... it's a pedal that you stomp on all the time. I just don't get this one.
08-06-2019, 12:20 AM | #14 |
Drives: 2017 Camaro SS 2ss Nightfall Gray Join Date: Aug 2018
After one week of use, it would have some scratches on it anyway. When I upgraded mine, they also had some scratches on it
ACS front spoiler, rear spoiler, side skirts and rock guards (gloss black). Real carbon fiber dash insert, real carbon fiber gear bezel, GM dark tail lights, Gm black badges(Emblems and ss)
Powder-coated gloss black factory 5 spoke split wheels Roto fab Biggulp CAI Full paint correction with cquartz finest ceramic coating Whipple 2.9 ARH Long tube headers with High flow cats 1le sway bars F&R BMR Upper and lower trailing arms Hurst short throw shifter |
