08-06-2019, 02:12 PM | #29 |
Drives: around in circles few days a month Join Date: Mar 2019
I ran my tires at 30 psi at the beginning of every session last weekend. I check before I go out on track every time. Seems to work well.
08-06-2019, 02:27 PM | #30 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
I do NOT lower them to 28 after each run, but rather to 36 which is about the top hot temp i like (and maybe even less based on actual wear). So if i come in first run and they are at say 38 i lower to 36. If i come in after a second run and they are 36 i leave them. But most often they will continue to climb past the 36 mark for the first 2 or 3 runs and require bleeding down to 36. Then they usually settle on 35/36 hot for the rest of the day (once the ambient temps stop increasing). Hope this clarifies. Cheers! |
08-07-2019, 09:30 AM | #31 |
Drives: 2013 C6Z06 Join Date: Nov 2016
Got ya, but I wonder how many psi you have already dropped with a good cool down lap? Do you ever check the DIC right at the end of your hot laps? That's what I'm going to try to remember to do.
Most times I don't even go right back to my pit and continue to drive around for more cooling after the cool down lap because the brakes and wheels are still so hot. |
08-07-2019, 09:44 AM | #32 | |
08-07-2019, 10:03 AM | #33 | |
Drives: Rally Green 2020 ZL1 1LE A10 Join Date: Jul 2018
Pressures were pretty close on my gauge to what the car was showing as well when I pitted. |
08-07-2019, 10:26 AM | #34 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Tire tread surface temperature cools off far more rapidly than does the rubber temperature on the inside, and the air inside necessarily cools off more slowly than that. Meaning that the inflation pressure really isn't dropping as fast as a probe type tire pyrometer might suggest even though that's the better measure for tread temperature. Rubber just isn't a very good conductor of heat, and aluminum wheels are going to be gaining heat from hot brake components for a while before they're cool enough to help pull heat out of the air inside the tire (instead of potentially pushing heat into that air). Norm
'19 WRX 6M (the family sedan . . . seriously) |
08-08-2019, 09:06 AM | #35 | |
about .5-1.5 psi Maybe I've been leaving time on the table by not bleeding between sessions, but I'm still skeptical because my first session is never the fastest. (Yes more practice, more seat time in same day, blah blah I understand why i get faster during a day) |
08-08-2019, 09:15 AM | #36 | |
08-08-2019, 09:16 AM | #37 | |
08-08-2019, 09:21 AM | #38 | |
I have some PZero scrubs btw not freshy Hoosiers. |
08-08-2019, 06:52 PM | #39 | |
That does put the pressures at the end of session 1 up above my target pressure. But at least I can bleed back down to maybe a psi or two below my target pressure depending on how long I put off doing so, and I'd rather bleed down from hot or at least 'warm' than from closer to 'cold' because that's where the conditions of the day are putting them. I'm still apt to be a psi or two past target by the end of session 2, so I usually make another adjustment, this time paying closer attention to whether it was the right side tires or the left side tires that gained more pressure. Since I've had more best lap times of the day in session 2 than in any other session, that hasn't been a bad approach. But I may need to rethink the post-session 2 bleeding.. Norm
08-10-2019, 07:14 PM | #40 |
Good thoughts Norm. No matter what strategy one uses: tire pressure matters and every single pro team pays extremely close attention to it.
08-10-2019, 08:28 PM | #41 | |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
Yes, you are probably not driving hard enough. If that is the case, then focus on fundamentals. Keep the cold starting pressure at 28 PSI and adjust as needed during the day if pressures rise. Also verify your tire pressure gauge is accurate. TPMS is ok as an indicator, but you need an accurate hand held gauge. One of my TPMS is 1.5-2.0 PSI off. The tires handle dramatically different at 36 vs. 38 PSI. Don't go over 37 PSI hot.
08-12-2019, 07:59 AM | #42 | |
Thanks,
I check with both yes. I was 36 in the front and 38 in the back in the pits after each session. The Cosworth app showed the same when I got home and reviewed the data. (on the previous page.) Next time I go out ill make sure I'm no more then 37. I'm about 1/4" above the winged foot on the wear marks on both front and rear at those pressures. Heres my 2nd session. Last lap starting at 13:50 was my fastest. It was fun but lots of traffic. |
