06-29-2021, 09:30 AM | #43 |
Drives: 2021 1SS 1LE Join Date: Nov 2020
Awesome. I decided to go with the 3Rs as I don’t really don't put a ton of laps in, but focused hard ones. I’m working on a step by step testing plan which I’ll write up at some point.
08-10-2023, 01:09 AM | #44 |
Drives: Chevy camaro Join Date: Jun 2023
What rim size and offset for the 315? Did it clear ok?
08-10-2023, 11:44 AM | #45 |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
Well I have posted this before but I have run APEX EC7 ET25 wheels (BMW fitment) on all four corners with RT660 tires 315 30 18. On the FRONT wheels I run a 8MM spacer to get enough clearance on the strut side of the wheel. You probably need at least -2.0 degrees camber so that you dont have tire poke at the top center part of the wheelwell.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
