03-17-2016, 06:53 PM | #1 |
Drives: 2016 Camaro 2SS - Red Hot Join Date: Mar 2016
Fix Rattle/Squeaks from Center Console Area
So over the last 2 days I have developed an awful rattle/squeak from the middle of the car. With the help of a friend, I was able to track it down to the center console area. Upon further inspection, I realized it was most likely under the car since the DriveShaft tunnel is so high in the car.
I got the car lifted up using a jack and crawled under. I started moving anything I could to find the source. Almost instantly I found what I assume is a gas line rubbing the heat shield. The heat shield was also rubbing on the car. I grabbed a small pry bar and finessed the shield and line away from each other. I gave it a quick test drive around the block and all is well with the world now. Just wanted to post up so any new buyers that hear similar noises, think to look under the car before pulling the dash/console apart. I've attached a picture of the hose. I had limited room under the car so it's a pretty close picture. Mine was on the passenger side/middle of the trans tunnel.
Red Hot 2SS, 8A, NPP, Sunroof, Nav
03-17-2016, 08:34 PM | #2 |
Drives: Gen 6 Camaro RS Join Date: Dec 2015
Thanks for sharing.
