10-09-2019, 06:06 PM | #1 |
Drives: 2017 Camaro Convertible SS Fifty Join Date: May 2018
TSB for front brakes, transmission
SOB, got to bring the Camaro in thanks to sliding piece that once again, within 13 months, needs to be replaced.
Anyway, been dealing with squeaky front brakes and the tranny jolting, etc. Anyone know if there is a TSB so I can streamline this with the service dept.
2017 Camaro SS FIFTY Convertible
10-09-2019, 06:40 PM | #2 |
Tbh, I didn’t know there was a TSB for the squeaky brakes. But if your talking about the A8 shudder it’s 18-NA-355
10-10-2019, 06:00 AM | #3 |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
I got the squeaky front brakes as well... Interested to find out if there is a TSB.
10-10-2019, 06:22 AM | #4 |
Thank you Al Oppenheiser!
There is a TSB for low pitch “fog horn” vibration, not squeak.
https://www.camaro6.com/forums/showthread.php?t=530909 |
10-10-2019, 08:40 AM | #5 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
My brakes just started squeaking a few weeks ago as well. Car has 17k miles on it.
10-10-2019, 09:04 AM | #6 |
10-10-2019, 09:44 AM | #7 |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
I don't have any squeaking with the PowerStop pads. And less dust than the OEM.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
10-10-2019, 09:49 AM | #8 |
Who Needs to KNOW?
Solved that problem by being hard on the brakes 16K miles, all 4 corners nearly due for replacement. That's personal record.
ing for grip.
10-10-2019, 09:59 AM | #9 |
Drives: 2023 SGM 1SS Join Date: Dec 2017
TSB 18-na-372 addresses brake squeak/squeal on SS with 4 piston Brembos with light brake application. There's a new rotor with different composition that is supposed to reduce or eliminate the noise. Done under warranty.
2023 1SS SGM A10 NPP
10-12-2019, 06:26 PM | #10 |
Ok, so picked up my Camaro from service today.
1- They replaced the front rotors via warranty due to the squealing. 2- They did the trans fluid exchange. 3- The reason I brought it in was because the panel popped due to the slider or so I thought. Turns out the issue is something different altogether. Apparently, the arms are so badly bent that it does not properly go forward AND they are broken away from mount. I purchased the vehicle new at the end of May 2018. Top was replaced in August (ordered in July). The current service place is different and believe that when the top was replaced quite a bit of damage was done. I have no idea what was replaced when the top was replaced, would think the arms would have been replaced, so either it came from the factory this way or it was busted when the new top was put on. Vehicle has to be seen by another tech and this should be fun as I am certain these parts will have to be ordered, which means I can't use the top for some time to come.
10-12-2019, 08:25 PM | #11 |
Drives: 2016 Camaro SS Join Date: Jun 2019
I've had the front brakes squeak but I've only noticed it when I'm pulling into the garage.
10-12-2019, 08:53 PM | #12 | |
States that it is due to performance brakes being used in everyday traffic. Replaced with new improved part listed on bulletin.
10-13-2019, 08:29 AM | #13 |
Drives: Chevy Camaro Join Date: Jul 2019
I have a 19 SS and mine started making noise, hard on the brakes a few times and it seems to have went away, if it comes back, I take the pads off and put some anti seize on the back of the backing plate , I think that's what the dealer is doing.
10-14-2019, 12:29 AM | #14 | |
That is what the TSB states to do.
Thread Tools | |
