07-04-2019, 01:24 PM | #1 |
Drives: 2018 1SS Join Date: Dec 2018
Play in BMR Sway Bar Links
Anyone else install the BMR sway bar end links? I recently had them added to the GM 1LE sway bar kit, and there is a some play in the rear. I started hearing a clicking type noise, and since I just had them installed, I checked them out. When pulling side to side, there is a little play that is causing the clicking. Not much, one millimeter +/- 1mm. But much more than I would have expected, since I expected zero play. Anyone else experience this? Is a little play normal and I just never noticed it before because of the stock rubber bushings? I am a little concerned because I have two track days next week, and the shop I use is closed for the holiday.
2018 Red Hot 1SS, GM lowering kit & 1LE Sway bar kit, ZL1 1LE solid rear cradle bushings, BMR sway bar end links, GM CAI w/tune, Pray ported IM, Mamo ported TB, VS Forged VS07 rims 20x11 & 20x10 w/ Michelin PS4S
07-08-2019, 09:05 AM | #2 |
Drives: '18 2SS/EU (+Recaros) M6 Red Hot Join Date: Nov 2018
There should not be any play. Sounds like either it is not torqued properly or the end link is defective?
07-10-2019, 10:27 PM | #3 | |
It is definitely torqued correctly. I took the car to the track on Monday, and it felt super loose, so something is definitely not right. I have contacted Frank at BMR with the details, and he is looking into it. We'll see.
07-29-2019, 09:14 PM | #4 |
Drives: 2017 1SS 1LE...makes me go YeeeHaw! Join Date: Mar 2012
Did Frank every solve the problem?
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late! |
08-20-2019, 04:17 PM | #5 |
08-20-2019, 04:29 PM | #6 |
adjustable or non adjustable?
