Old 07-10-2018, 10:28 PM   #1
CamaroSS50
Drives: 2017 Camaro Convertible SS Fifty
93 Octane Los Angeles...
As many that live in the People's Republik of California know, you can't get 93 octane anywhere in Los Angeles.
Oddly enough, there is one place near me that sells 100 Octane.
Question, aside from spending $8.99 per gallon, would there be any benefit from gassing up with 100 Octane?
2017 Camaro SS FIFTY Convertible
CamaroSS50 is offline   Reply With Quote
Old 07-10-2018, 11:12 PM   #2
dfwcowboy
dfwcowboy's Avatar
Drives: 2024 ZL1 M6, 1969 Cessna Skylane
In a stock engine, probably not. Higher octane fuels allow for higher compression ratios without knocking. If your engine starts knocking, the computer compensates, but the price of this is reduced power and efficiency. If you have no knocking at 93 octane(or lower), the benefit from raising octane very quickly reaches diminishing returns.
dfwcowboy is offline   Reply With Quote
Old 07-11-2018, 02:35 AM   #3
Larrio Andretti
Drives: Really Fast
Not probably not. DEFINETELY not. There is no benefit from higher octane than your car was tuned for. Unless you are on the track you will never notice the difference between 91and 93. Your Camaro is set up from GM to use 91 MON.
THIS SPACE FOR RENT
Larrio Andretti is offline   Reply With Quote
Old 07-11-2018, 07:33 AM   #4
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
Only benefit would be the smell.
Old 07-11-2018, 08:38 AM   #5
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
Unless it was tuned for it, no benefit, and from my understanding - the way to go IF YOU'RE GOING TO TUNE is E85, not 100 octane.
Need4Camaro is offline   Reply With Quote
Old 07-11-2018, 09:15 AM   #6
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
Look online and you should be able to find a chart that tells you how many gallons of 100 you need to add to 91 to get to 93.
Old 07-11-2018, 10:34 AM   #7
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
stock engine with 100 no you have to be tuned for it but i would fill up with 93 over 91 if it was available...there is a place in hb that sells 100 vp octane and also a 76 in la habra that i remember sells like 93 98 and 101
Old 07-11-2018, 11:04 AM   #8
Chef-j
Drives: 2018 Camaro 1SS
Time to move
Chef-j is offline   Reply With Quote
Old 07-11-2018, 12:38 PM   #9
ABM1SSSG3
ABM1SSSG3's Avatar
Drives: 2017 Arctic Blue Metallic A8 SS
Go to your closest station that pumps 100 octane unleaded. Put 4 gallons of 100, and fill the rest with 91. Assuming you've been using 91, this will give you a 92.9 mixture. You can use 3 gallons of the 100 on future fill-ups to get you there. You'll have to make 2 transactions each fill-up.
2017 SS Arctic Blue Metallic A8 GM big brake kit SG3 Lowering & FE4 sway Bar Kits
ABM1SSSG3 is offline   Reply With Quote
Old 07-11-2018, 12:58 PM   #10
Bad Anvil Garage
Bad Anvil Garage's Avatar
Drives: 2000 GMPPSV SS & 2017 ILE SS
Can you get 89? Your car will learn 89 over time.
Bad Anvil Garage is offline   Reply With Quote
Old 07-11-2018, 01:27 PM   #11
Need4Camaro
Why would you choose 89 over 91?
Old 07-11-2018, 03:15 PM   #12
Bad Anvil Garage
I forgot about 91. Obviously use the highest you can find. The car will learn timing to avoid detonation.
Here we have 87, 89 & 93.
Old 07-11-2018, 03:23 PM   #13
CamaroSS50
I have only put in the highest I can find which is 91.
My other vehicles use 87
I thought I read that the Camaro must have 93, which I thought using 91 was the issue I was having, i.e. Popping, hesitations, etc.
Old 07-11-2018, 03:25 PM   #14
CamaroSS50
Originally Posted by Chef-j View Post
Time to move
Not a day doesn't pass that the thought doesn't run through my head.
