Old 01-04-2016, 07:42 PM   #1
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
any boosted guys have 3.91s and want to swap back 3.45?
Wonder if anyone here with 3.91s are looking to go back to 3.45s? Looking to swap if any interest, I have a perfect working 3.45 diff
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 01-05-2016, 09:40 AM   #2
Js2fst
2010 transformer
Js2fst's Avatar
Drives: 2010 ss camaro
We went to 3.23
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
Js2fst is offline   Reply With Quote
Old 01-05-2016, 04:59 PM   #3
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
1le diffs go for 1200, SS diffs go for 600
good luck finding a sucker to go for that one
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 01-05-2016, 07:06 PM   #4
BradySS
Drives: 2010 Camaro 2SS
I thought you wanted to stay with that gear ratio with the TH400 for the highway. What's making you want to change?
BradySS is offline   Reply With Quote
Old 01-06-2016, 11:20 AM   #5
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
Because 3.91s are fine on the highway
Bo White is offline   Reply With Quote
Old 01-06-2016, 11:58 AM   #6
BradySS
I'd prefer 3.91 gears overall for the TH400 considering its tall first gear it helps it get out of the hole but I'd hardly call 3.91s "fine on the highway" for your normal person.
Old 01-07-2016, 01:50 PM   #7
Bo White
Bo White's Avatar
Its equivelent to 3.55s on a old school 1st or second gen Camaro. I know plenty of guys that have DD cars like that with 3.73s including myself.
Old 01-07-2016, 03:26 PM   #8
BradySS
I knew it would be high as far as rpm because I had a Mustang with a C4 Trans which is like the TH400 with being a 3 speed and 3rd gear being 1.0. I had a 3.73 rear with a 26" tire and freeway wasn't that great. So I'm just going off that but putting it into this calculator found at http://www.csgnetwork.com/multirpmcalc.html
You'll be 3284 RPM at 70mph with a 3.91 and a 1.0 3rd gear and that's if you're running a 28" tall tire. Take into consideration this is calculated without converter slip so the RPM will actually be even higher then that 3284 number.
Is it doable? Yes but not for your average car guy. If you're putting a TH400 into a newer gen Camaro you are not your average car guy. I'd do 3.91s or 4.10s personally.
Old 01-07-2016, 03:52 PM   #9
Bo White
Bo White's Avatar
Correct, th400 swap isnt for the average guy.
Your mustang was the same as my older camaro. I was 3500rpm at 70 with 3.73s and 3000 stall.
My first camaro was a 78 Z28 and it had factory 3.42 and thats just a touch taller than the 3.55 comparison I used.
