05-19-2018, 12:41 PM | #15 |
Drives: 2017 corvette z06 Join Date: Dec 2017
The rear end is secured with a chain at the back of the trailer which is used to secure the car through the suspension
05-19-2018, 12:50 PM | #16 |
Romans10:9-13
Drives: /\yes, this is me/\ Join Date: Nov 2008
Really the car is held on by the front tie downs over the tires. Crank on them
05-19-2018, 01:37 PM | #17 |
Drives: Sold! Join Date: Nov 2017
Also watch the angle of the ramps to the body of the trailer or you may bottom out as you top the ramps and begin moving down the trailer. Mine did on flat ground and I don’t have side skirts or anything.
05-19-2018, 04:14 PM | #18 |
Flyin NOE
Drives: 2018 ZL1 (A10) Join Date: Apr 2017
Thanks everyone, appreciate the insight.
05-19-2018, 07:14 PM | #19 |
Drives: 2018 Mosaic Black Metallic ZL1 A10 Join Date: Sep 2017
Be very careful. I messed up 2 rims trying to load mine.
05-20-2018, 08:01 AM | #20 |
Drives: 2015commemorative vert 2SS Join Date: Oct 2013
I did. Hauled my new back from another state. Had to removed the plastic lower air dams, other than that it fit perfect. Just be careful to remember that when exiting the door is very close to that fender cover, if you forget to put it down. Looks like the guys with vettes needed boards, you dont with the camaro.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
05-20-2018, 11:09 AM | #21 | |
Flyin NOE
05-21-2018, 07:56 AM | #22 |
Yes... I re-inserted the shipping spacers for that extra inch of vertical in the front suspension. Forgot to say that, but it gave me just enough to clear the loading ramp, and the metal stop at the front of the trailer. Trailer road perfect, handled great. No bad habits or any issue's for the entire trip I used it on.
05-21-2018, 08:14 AM | #23 | |
Romans10:9-13
05-21-2018, 09:21 AM | #24 |
Drives: 2020 ZLE Rally Green A10 Join Date: Sep 2016
That front tire stop on the Uhaul trailer is exactly 6" tall. The front splitter on a ZL1 at the very front has a 6" clearance, and there is a lip behind that with a 4" clearance. So you have to do something to get at least 2" or more of clearance at the front of the ZL1 so your tires can pull up to the bump stop.
Unless you have the issue they put a TSB out for where the front of your car sits too high because of the springs.... There is also two different uhaul trailers. The red colored ones will destroy your rims because it's not wide enough, you want the silver ones as shown in the provided pictures. No matter what I say, use a tape measure before you load your car but have wood or something ready to get that front end up. |
05-21-2018, 02:02 PM | #25 | |
Flyin NOE
05-22-2018, 03:45 AM | #26 |
Camaro owner for 29 years
Drives: 96 Viper GTS/09 Sky Redline/95 Z28 Join Date: Jul 2008
That front part of the trailer where you pull your front tires up to is held on by a few bolts. I removed it, drove my Viper on the trailer, and then reinstalled the front wheel stops which were now BEHIND the front airdam. Take a look and it is obvious what I'm doing a terrible job trying to explain. LOL!
I had to go to Home Depot and they cut specific lengths of lumber for me to extend the ramps out to give me a good enough angle to get up them. Best of luck. |
05-22-2018, 05:46 AM | #27 | |
Flyin NOE
I'm think one 2x10 at ~16 inches long for each wheel out to suffice as both a ramp and platform for the front of the trailer. |
05-22-2018, 10:08 AM | #28 |
The Doctor is in
Drives: 2016 Camaro 2SS Nightfall MRC NPP Join Date: Jan 2016
I am doing the same thing in a few weeks with my SS for an autocross event. I’ll stop by and look at the trailer in a few days.
2016 2SS MRC NPP Sunroof Nav, Forgestars CF5V with RE-71r 275/35r19s in front and 285/35r19s in rear
2017 Silverado 1500 LT Z71 Double Cab 2017 Honda Pilot Elite |
