07-08-2015, 03:18 PM | #1 |
Drives: 2013 Camaro SS and 2016 Camaro SS Join Date: Jun 2014
Hurst Stage 1 Suspension Kit for the 2013-2014 Camaro SS and 2012-2014 Camaro ZL1
Part #6320001
Application: Fits 2013-2014 Chevrolet Camaro SS and 2012-2014 Chevrolet Camaro ZL1 Description: The Hurst Stage One Suspension Kit is an excellent choice for firming up the handling of your car and giving it that "Just Right" stance. This suspension kit will lower your vehicle approximately one inch (depending on the application), and also increase the roll stiffness. These two small changes close up that fender gap, lower your center of gravity for improved handling and braking, and keep body roll to a minimum. From the very first drive, you will notice a more neutral balance to the vehicle, precision turn-in capability, and increased cornering grip. Through careful design and rate tailoring, the Hurst Stage One Kit accomplishes all of the above while still being street friendly - truly a "win-win" situation. Features and Benefits: -High Performance Handling -"Just Right" Stance for the perfect muscle car look -Daily driver / Street friendly -Performance swaybars dramatically reduce body roll -Neutral Handling Balance / Accurate Turn-In Response -Lower Center of Gravity - Will lower the vehicle approximately 1 inch (depending on application) -Improved Aero Efficiency = Small Gain in MPG Part Attributes: Use Location: Suspension Sway Bar Material: High Strength Steel Sway Bar Diameter (in): 1.14(Front)/1.26(Rear) Sway Bar Color / Finish: Hurst Gold Powdercoat Spring Uncompressed Length (in): 11.500(FRONT)/10.375(REAR) Spring Uncompressed Diameter (in): 6.375(FRONT)/5.560(REAR) Spring Rate: 134 LBS/IN (Front) Spring Position: Front & Rear Spring Maximum Compressed Length (in): 3.689(FRONT)/4.089(REAR) Spring Maximum Compressed Diameter (in): 6.375(FRONT)/5.560(REAR) Spring Color/Finish: Hurst Gold Powdercoat Rear Sway Bar Type: Hollow Progressive Rate Spring: 230-425 LBS/IN (Rear) Position on Vehicle: Front/Rear Package Quantity: 1 Package Contents: 4 Springs, 2 Sway Bars, & Hardware Mounting Hardware Included: Yes Item Grade: High Performance Front Sway Bar Type: Hollow Constant or Variable Spring Rate: Constant(FRONT)/Variable (REAR) Coil End Type (2): Pigtail Coil End Type (1): Pigtail Bushings Included: No Bar Size (in): 0.545(FRONT)/0.610(REAR) For additional questions, please call our sales department at 707-544-4761. Last edited by HurstPerformance; 07-08-2015 at 03:29 PM. |
02-16-2017, 10:40 AM | #2 |
Due to these kits being discontinued, we offering them at an incredible price through our eBay Store. Don't miss out on a chance to get a great deal on a great kit.
Tags |
hurst, lowered, spring, sway, zl1 |
