Old 12-28-2017, 05:37 AM   #15
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
-26C or-14F this morning. No issues here.
First crank was a little slow for the first second but fired right up. No issues shifting.
Tire pressure went from from 34psi hot down 24psi when frozen
Old 02-26-2018, 04:14 PM   #16
Colt_H
Drives: 2017 2SS - MRC, NPP, M6
#metoo
Colt_H is offline   Reply With Quote
Old 10-29-2019, 12:23 PM   #17
fahimghaffar
Drives: 2018 Camaro ss
I have a 2018 Camaro SS
I am having same 2nd gear issue. One the customer got it fixed and found out that is a defective transmission housing. Here is the link to the video. https://youtu.be/FxngwiF7_Wg
GM knows about it but they are telling their dealer to tell customers that it is normal. Everybody, we need to report this issue to NHTSA.gov. Here is the link for that https://www-odi.nhtsa.dot.gov/VehicleComplaint/
All these camaoros have defected transmision housing which is causing multiple symtoms. For example, hard to shift to 2nd when upshift or downsift, 2nd gear popping out and shift into neutral, missing 2nd gear and sometime grinding.
I spoke to 2 dealers and they both have different openion. One says that i need skip shift eliminater and the other one says that it is normal to have symtoms like that also Advised me not to use the 2nd gear. Which is bad beacuse we spent a fortune buying this car and then we are unable the use 2nd gear.
Please everybody, go NHTSA website and file a complain because they are not going to fix it until government institution files a lawsuit against GM
fahimghaffar is offline   Reply With Quote
Old 10-30-2019, 07:36 AM   #18
Cechk01
Drives: 2016 Camaro 2SS M6
GM is not going to do any recall unless is a safety issue
Cechk01 is offline   Reply With Quote
Old 10-30-2019, 03:02 PM   #19
protovack
Drives: 2019 2LT 2.0T M6 Riverside Blue
please stop posting in the bumped threads. People should respond to the current thread started by the guy bumping all these threads.
protovack is offline   Reply With Quote
