11-14-2019, 02:25 PM | #1 |
Drives: 2019 ZL1 1LE Join Date: Jul 2019
Brake issue while on track?
Hi Gents...Trying to problem solve before ZLE goes into dealer for observation.
2019 ZL1 1LE...3000 miles total, last 800 with about 700 track miles. Drove to track today, about a 30 min. drive, car felt perfect as usual. Was on track and as I built up speed I started to feel a vibration, I believe mainly under braking. It felt like it was getting worse as I kept lapping faster. I pulled into pits to check tires, thinking maybe the PSI dash gauge was broken and I might have had a flat (all were at 33PSI). Put my hand close to the left front wheel, normal heat, nothing looked unusual. Put my hand by right front and WOW, the heat seemed twice as hot coming off that wheel area. Let car cool down, headed home, another 30 min drive mainly HWY, car felt normal again. Warped rotor? Wheel bearing issue? Brake pad problem? Any ideas? |
11-14-2019, 04:04 PM | #2 |
@viurniel
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT Join Date: May 2016
I experienced something similar (not on track) and it was only debris that the tire picked up. I cleaned the tire up when cool, and solved.
11-14-2019, 04:15 PM | #3 | |
Is this what you mean? Are you referring to debris on the inside of the wheel itself our something got between the caliper/rotor that caused vibration? |
11-14-2019, 04:42 PM | #4 |
it could be anything listed above...brakes/rotors with material embedded in them or tires with buildup. Keep driving if you don't feel anything serious through the steering wheel.
11-15-2019, 12:32 AM | #5 |
Drives: 2017 1SS/1LE Join Date: Sep 2016
What PTM/Stabilitrac/Traction Control settings were you using? Was this primarily on a CW or CCW track?
It sounds like you may have some uneven pad transfer and may need to bed your brakes in again. It's a common occurrence when you're using the same pads for street and track. |
11-15-2019, 07:27 AM | #6 | |
@viurniel
11-15-2019, 09:20 AM | #7 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
I would get an infra red heat gun. Harbor Freight has some cheap ones that work. Do some spirited driving and hard straight line braking. Shoot the rotor temps. Is one way hotter than the other?
Also like mentioned above, watch what mode you are in on track. Too much active handling intervening can really heat up a brake corner. I watched a car once come in the pits with a rear brake smoking. That corner was way over temp from running the track, sliding the corners with full AH. He was trying to slide it to rotate the corners, but active handling was really hammering one corner brake trying to keep the car straight. Take a peak at the 4 front pads, are they wearing evenly. After a few hundred road miles to get all the track rubber off, wouldn't hurt to have the front tires balance checked. Just to rule out a weight possibly came off. |
11-15-2019, 10:35 AM | #8 |
Drives: 2018 ZLE, 2023 C8, IMSA MX-5 Join Date: Jul 2019
Same issue. Was piles of molten rubber that had adhered to the inside of the rim throwing it out of balance. Usually more on one side front and back. I carry a scraper and hit the insides during tire rotations at lunch or end of day. Also agree that less brake intervention and less uneven rotor heat in Track Sport 1 or 2 versus Tour or Track Wet/Dry.
11-15-2019, 05:34 PM | #9 |
Thx for all the comments.
I just got to the track that day and was on 3rd lap...first two were just cruising around as I felt the "imbalance/wobble" build up as I applied more "spirited" braking. I believe I was in Track - Sport 1 which is what I typically start in (but may have been Track - Dry, on that particular session). I'll pull the wheels and check for any build up, along with pads and bearings while there. |
11-15-2019, 09:01 PM | #10 |
Drives: 2015 Z/28 Join Date: Jun 2011
If it is only under braking, most likely deposits on the front rotors or warping of the front rotors from your last outing at the track. I have warped 2 sets of fronts so far so it does seem common, (at least for me)
11-15-2019, 10:13 PM | #11 | |
Lover of Speed
Drives: 2018 ZLE Join Date: Feb 2016
PS What track was this? I just moved from Phoenix.
Killer Whale Racing
2021 One Lap of America Track Videos 2019 One Lap of America Track Videos 2017 One Lap of America Track Videos 2022 Ram TRX 2018 Camaro ZL1 1LE 2020 Range Rover Sport SVR (Sold) 2014 Grand Cherokee SRT (Sold) 2014 Camaro Z/28 (Sold) |
11-16-2019, 02:44 PM | #12 | |
Thx and I'll definitely look it up. Key question now, if that's what it is, how to remedy it? As for the track, I'm a member at Apex Motor Club. Here's a post under track section. You'll see my PDR video from it as well. https://www.camaro6.com/forums/showthread.php?t=564829 |
11-17-2019, 07:10 PM | #13 |
Lover of Speed
Ok cool. Apex was just opening as I left, sucks that I just barely missed it after hearing about it for years. Looks fun though.
Killer Whale Racing
11-18-2019, 01:05 PM | #14 |
Quick update...Brought it in to dealer, they cleaned the rotors and machined them. Calipers cleaned up as well...no issues so far, so problem solved.
Anyone know how consistent this maintenance is for a mainly track ZL1 1LE? I have about 10 track days on them...about 4 , 15 min sessions per track day. I understand it depends on the track config, how much braking, etc. Just curious. Not sure I can machine them again, I might have to replace next time. Common? |
