Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LFX Engine, Exhaust, and Bolt-Ons
Old 06-24-2023, 08:00 PM   #1
Vaddy
Drives: Chevrolet Camaro LS 2015
2 Step now available!
If you ever wanted 2 Step but didn’t want to figure out how to wire the WOT box which is pretty universal. I figured it out for you. By using a MSD 2 Step for the 2016-2018 Camaro SS, I was able to wire the connectors from the E85 harness to the ones on the 2 Step, and it works! I haven’t seen another V6 Camaro 2 step so this might be a first.
I explain a little bit in this video on how it looks and what I did:
https://youtu.be/6Z0CIDN4M_I
But all I did was order 6 E85 harness from: https://www.bmotorsports.com/shop/pr...oducts_id/4154
And the MSD:
https://www.holley.com/products/igni...ls/parts/87331
Cut off the excess wire, used Aviation Snips to cut the plastic on the connector connecting directly to the coil to be able to have clearance on the plastic slabs because the ones you can buy from like DSX tuning is 300 a piece, and I guess this one is not technically for the LFX. Then wire it exactly how you see it, make sure you get the orientation right, it’s easy to forget and you might wire stuff backwards. Set it up in the car, add your button and now you have 2 Step!
Vaddy is offline   Reply With Quote
Old 06-24-2023, 08:03 PM   #2
Vaddy
Want to also mention, you can cut off the excess connectors as it’s made for the V8 but make sure you don’t cut off the one thats wired with 6. I’m sure that one is important.
Old 08-08-2023, 01:03 PM   #3
Ck1984
Drives: 2015 camaro LFX V6
what exactly does a 2 step do?
2015 2LT LFX 3.6L
FE2 Sport Suspension
MXO-6 Speed auto w/Tapshift
Aftermarket Oval mufflers
Ck1984 is offline   Reply With Quote
Old 08-08-2023, 01:08 PM   #4
NoDakZ/28
NoDakZ/28's Avatar
Drives: 2014 Z/28 CTF
It allows you to have consistent launches by keeping the car at a certain rpm and/or build boost on the line.
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM
NoDakZ/28 is offline   Reply With Quote
