Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LFX Engine, Exhaust, and Bolt-Ons
Old 01-11-2017, 06:47 PM   #29
crc91
crc91's Avatar
Drives: '14 1LS
Originally Posted by earcia66 View Post
Thanks for posting it, i couldnt remember my password or login for the longest time! Thought i had to make a new one lol
Well welcome back!
Patiently waiting for my 2023 SS 1LE
crc91 is offline   Reply With Quote
Old 01-11-2017, 07:20 PM   #30
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
(Some of the info was removed as I couldn't remember, and my lap top with the run files on it died so I can't check conditions)
Type and make of dyno: Dynojet 424xLC2
ODO at the time of the dyno: ~3500
Manual/auto: Auto
Modification: JacFab ported intake manifold, and intake manifold spacer only
Correction used(STD or SAE): SAE
Result: See below
Blue line, stock. Red line, Intake manifold spacer only. Top maroon line, Ported intake manifold and intake manifold spacer only.
Old 01-11-2017, 08:30 PM   #31
djcolopi
djcolopi's Avatar
Drives: @orange_maro
The google spreadsheet has been updated! Jason in addition to adding the 3 pulls to each of the respective sections, I made a separate page just for you. Since its in one page with no other information it should allow people to easily see the documented differences between your modifications.
Instagram @orange_maro_
djcolopi is offline   Reply With Quote
Old 01-11-2017, 08:34 PM   #32
Kenny Camaro
Drives: 2013 1LT RS Camaro
Awesome DJ! It's great that you have decided to take your time and effort to reboot the LFX dyno thread. Now people can see improvements on this thread that people and vendors are talking about.
Kenny Camaro is offline   Reply With Quote
Old 01-11-2017, 08:37 PM   #33
djcolopi
djcolopi's Avatar
No problem man just giving back to the LFX community, well worth the time spent
Old 01-17-2017, 10:55 AM   #34
Jason@JacFab
Thanks for doing that... I took a look at it and just by looking at the numbers, you can't really see any gains from the spacer... Looking at the google spread sheet stuff, I see an insert button. Could you possibly insert the picture of the dyno graph into my page so people can get a better visual?
Old 01-17-2017, 10:59 AM   #35
djcolopi
djcolopi's Avatar
Just for you Jason. Image of the dyno sheet inserted at your request.
Old 01-17-2017, 11:37 AM   #36
djcolopi
djcolopi's Avatar
Realized I did not add my stock numbers to the spreadsheet. So here Inferno is stock.
Type and make of dyno: Dynapack 53 4WD
Temperature:
Manual/auto: Auto
Gear used(3rd or 4th): 3rd
Modification: Stock
Result: 260rwhp/235ft*lbs tq
Old 02-21-2017, 05:14 PM   #37
sspade
sspade's Avatar
Drives: 2015 Camaro LFX A6
Just talked to Matt at Black Ops Motorsports, Forest VA (near Lynchburg).
He has a DynoJet 248 and charges 100$ for 3 pulls. Sound reasonable? This will be the first time this car has ever been on the dyno. Probably going to schedule it for next week sometime...
Anything I should know or ask going in?
Some others have guessed I will be at about 285 rwhp... sound about right?
Please share thoughts and comments. Will definitely be posting my results here when complete.
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
sspade is offline   Reply With Quote
Old 02-21-2017, 05:34 PM   #38
Kenny Camaro
Sounds good. I wish I could find a dynojet close to me. Only close dyno is a mustang. Did Will take your speed limiter off? Do you have z-rated tires? If the limiter is still on, or if you still have the stock tires on, you'll probibly do a third gear pull which usually read a little higher than a fourth gear pull. Good luck and good pull!!
Old 02-21-2017, 05:36 PM   #39
djcolopi
djcolopi's Avatar
Yes, that price is reasonable. Make sure you get a hard copy/print out of the sheet. Check to see if it includes AFR readings; it might cost extra.
This what what my performance shop charges; JE Import Performance
Standard Dyno Testing
2wd $90 4wd/AWD $120
* Includes setup on dyno and three runs with color dyno graph printout
2WD with 02 $110 4WD/AWD with 02 $140
* Includes same as above with Air Fuel ratio readings
Dyno Tuning
2WD $190 4WD/AWD $265
* Custom tuning by the hour
Dyno Rental
Bring your own tuner (restrictions apply)
First Hour & Hookup: 2WD $100.00 4WD/AWD$150.00
Each Additional Hour
2WD $75.00 4WD/AWD $100.00
All Day Rental (9am – 5pm)
2WD $575.00 4WD/AWD $750.00
If tuning multiple cars with dyno rental either by the hour or all day you will be subject to a set up fee per car after the first car.
2WD $25 per car
4WD/AWD $40 per car
Old 02-21-2017, 05:59 PM   #40
sspade
sspade's Avatar
Great info. Thanks guys. Yes, my tune removed speed limiter and increased rev limiter as well.
I have Toyo Proxes 4 Plus which I believe are Y rated to 180 MPH or so...
Old 02-27-2017, 08:30 PM   #41
Kenny Camaro
One more thing....the skinny pedal to the right, push that to the floor!!!
Old 03-06-2017, 01:36 PM   #42
Rapter9932
Rapter9932's Avatar
Drives: 2015 Camaro 1LT/RS
ODO at the time of the dyno: 26,500 mi (2015 RS)
Temperature: 51 Degrees
Manual/auto: Manual
Modification: CAI from Cold air Inductions, Borla Attack Axelback
Result: 279.53 rwhp/239.21 ft*lbs tq
Air/Fuel: 1:15.16
Fuel: 93 Oct
Rapter9932 is offline   Reply With Quote
