08-24-2023, 08:49 AM | #1 |
Drives: 2023 1SS 6 speed Join Date: Aug 2023
Installing 6x9s in the rear non Bose
I’m thinking of installing some 6x9 woofers (CDT) in the rear as subs, and a small amp. Are there any pre wired connections back there one could just tap into for power, ground, and inputs?
2023 1SS non Bose |
08-24-2023, 10:46 AM | #2 |
Electrical Engineer
Short answer: no. There is nothing pre-wired back there.
You will need to run wiring to the front. You want to snag signal from front left and right outputs. Don't try connecting to rear signals as it's a very weak signal. Power and ground are easy since the battery is in the trunk. You will need a turn-on signal so either get an AC LC-2i or an amp with auto turn-on and high-level inputs. Plan on pulling the rear deck to install them from the top or make a baffle to install from below. I have all of the necessary service manual documents for interior disassembly and factory wiring schematics for the car (I have the same one). I snagged all of it from a 3-day subscription to ACDelcoTDS.
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
08-24-2023, 10:58 AM | #3 |
couldn't make it easy by leaving a plug I guess lol. Good to know about the side/rear speaker outputs being weak, I would have used those.
08-24-2023, 12:16 PM | #4 |
Drives: 2016 Camaro SS Join Date: Oct 2021
Not necessarily weak but I believe they are not a full range output and roll off the bass at higher volume levels.
2016 Camaro 2SS 759whp 686wtq tuned by KingLt1
Procharger D1SC - Diamond Pistons/Manley Rods BTR stage 3 cam - Circle D converter American Racing headers - Borla S-type |
08-26-2023, 11:45 AM | #5 |
Electrical Engineer
The rear signal is so weak, it is nearly inaudible when compared with the front signal. About 10dB down.
08-27-2023, 12:09 PM | #6 |
As has been said.. the rear side speakers and volume are weak. I’m not certain if they receive full frequency. I’m inclined to say no, after listening to my added rear deck speakers.
However, adding an amp in conjunction with the 6x9’s made quite difference in overall sound quality and volume. I’ve changed the front speakers as well, but that’s not what you’re looking to do. The rear speakers can easily be installed from below (I found this out after I dissembled everything) What a pain in the ass… You need to get yourself a nice sharp razor to cut the felt sound proofing from the underside of the deck. Install the speaker carrier with speaker studs facing down. I had to use a small drill to open up the speaker carrier to speaker stud openings. Once the carrier is secured, you can easily slide the speaker over the downward facing studs. I used two nuts to lock up each stud. If I sell the car and want to keep the speakers, they can be removed in minutes. See https://www.camaro6.com/forums/showthread.php?t=601570 |
08-28-2023, 11:28 AM | #7 | |
Electrical Engineer
My plan is to disassemble the rear deck this week. I will remove all of the interior panels to do acoustical treatments anyway. I expect it to be very annoying, but I have 3 days with the family out of town, and i've downloaded all of the instructions for interior disassembly. While this is my daily, that's by choice and I have other vehicles I can drive. It's finally going to be cooler temps this week, so the timing is perfect. I do agree with you that it makes a lot of sense to install the new rear 6x9 from below for an easier future swap. Just want a way to keep the bolt stationary so you can tighten the nuts from below. I think that I will modify the carrier with a dremel so a hex head bolt will not turn. I also ordered this harness: https://catalog.pac-audio.com/catalo...arness/lphgm72 We'll see how it works. My first step will be measuring the actual frequency response of the factory system, which will be necessary when doing EQ correction with the JL VXi amplifier platform.
08-29-2023, 11:23 PM | #8 |
metra lists a harness that provides two Chanels of low level outputs and a turn on lead.
08-29-2023, 11:24 PM | #9 |
The base sound system is pretty bad, probably the worst of all my recent vehicles in the last 5 years.
08-30-2023, 07:20 AM | #10 |
http://metraonline.com/part/AXLOC-GM31 This looks like it would make it easy to install amp.
08-30-2023, 11:19 AM | #11 |
On my 2016 1SS non Bose the amp was located in the rear and I added another amp and deck 6x9.
https://www.camaro6.com/forums/showthread.php?t=510907
2016 NFG 1SS A8
08-31-2023, 10:46 PM | #12 |
https://www.cdtaudio.com/cdtnew22/pr...rs/hd690cf.php
I’m going to put these in the back. |
09-01-2023, 08:17 AM | #13 |
I think I’ll get a US acoustics 2 Chanel for them 75w a 4 ohms should be fine. I’ll leave the main speakers alone.
09-01-2023, 04:17 PM | #14 |
Electrical Engineer
Those CDT are a fine choice. But do yourself a favor and get a 4 channel amp so you can upgrade the front in the future without a lot of hassle. You'll be happier when you get the fronts upgraded also.
